[SOLVED] Turn on and off relay with blynk button and/or physical button
this is the working code:
char auth[] = "xxxxx"; //insert here your token generated by Blynk
int relay1 = 12;
int button1 = 13;
int relayVButton = 0;
boolean relayState = 1;
boolean buttonState = 0;
WidgetLED led1(11); //virtual led
     Serial.begin(115200); // See the connection status in Serial Monitor
 Blynk.begin(auth, "ssid", "password"); //insert here your SSID and password
 buttonState = digitalRead (button1);
  if (buttonState > 0){
    relayState = !relayState;
      digitalWrite(relay1, relayState);
      delay(500);
pinMode(relay1, OUTPUT);
pinMode(button1,INPUT);
BLYNK_WRITE(V5)
  // Get the state of the VButton
  relayVButton = param.asInt();
  // put your main code here, to run repeatedly:
  if (buttonState > 0 || relayVButton > 0){
      delay(500);
//----------------button virtual led---------------
  byte inp = digitalRead(relay1);
  if (inp == HIGH)
   led1.on();
   led1.off();
