Just would like to ask if when will be available the connection to Thingspeak using the API.
Thanks and congrats for the whole blynk project!
We are partnering with ThingSpeak, but integration is planned for later.
Is it supported now? I am already using esp8266 with thingspeak to store the data but would I would like to see the data in nice ui provided by Blynk and control the board too.
If you are using Blynk on Android - just use the History Graph Widget.
Any one has an example of using WiFi (i.e. ESP8266) to connect to Thingspeak server, while running Blynk as well? Many thanks…
Hi there,
really cool App. I tried it out with an Arduino and an ESP8266 modul. Everything works fine!
But now I want to connect my sonsors to Blynk as well to Thingspeak. For a continous connection to Blynk, I have to set a multiple connection (“AT+CIPMUX=1”) and connect to both server via different mux_id’s. Right?
The connection to Thingspeak was successful (mux_id1). But how can I connect to Blynk via mux_id2? is there a method like “Blynk.begin(mux_id, auth, wifi, ssid, password)” or something like this? I saw the respectiv funktions in the ESP8266.cpp, like “sATCIPSTARTMultiple” or “sATCIPSENDMultiple”. But do not find a way to tell Blynk to use a specific mux_id to connect!
Would be thankful for help!
I’m interested too to integrate ThingSpeak onto my sketch.
Now I’m trying to integrate TS but with no success, maybe the problem is in the Blynk.begin and ThingSpeak.begin… every constructor try to establish own connection and then interfere with other.
Maybe can be possible to create a connection with the arduino library (in my case WiFi.h) and the attach Blynk and ThingSpeak to this connection?
I mean… now is…
WiFi.begin(ssid, pass);
Blynk.begin(auth, ssid, pass, myBlynkServer, 8442);
it’s possible to connect to Blynk server upon a existed WiFi connection like…
Blynk.begin(auth, myBlynkServer, 8442);
Blynk library don’t support multiple connection with esp8266, I’ve tried but don’t works, you must disconnect and reconnect for use more than one connection
i am running Blynk and Thingspeak in the same sketch.
but absolutely no idea how it works, i just know it does - i hacked at the code until it did~! pretty sure it reconnects whenever i send stat to thingspeak though…
this is my cut down code, but still some eccentricities in it… obviously took lots of the variable declarations out…
#define BLYNK_PRINT Serial //this is the debugging for Blynk
WiFiClient client;
const char* ssid = "XXX";
const char* password = "YYY";
const char* serverThingspeak = "api.thingspeak.com"; //this is the Thingspeak address
String apiKeyThingspeak1 = "ZZZ"; //Basement plenum control channel readings
char authBlynk[] = "WWW"; //insert token generated by Blynk
Serial.println(F(""));
Serial.println(F("BASEMENT VENTILATION PLENUM CONTROLLER - with Thingspeak & Blynk & Running Median & Email & Twitter"));
Serial.print(F("File name: "));
Serial.println(__FILE__);
Serial.println();
WiFi.begin(ssid, password);
Serial.println(F("Where's some WiFi??"));
delay(500);
Serial.print(F("."));
Serial.println(F("Found some WiFi!"));
long rssi = WiFi.RSSI();
Serial.print(F("WiFi signal strength (RSSI): "));
Serial.print(rssi);
Serial.println(F(" dBm"));
Serial.println("");
Serial.println(F("------------"));
Blynk.begin(authBlynk, ssid, password);
while (!Blynk.connect()) {
// Wait until connected
timer.setInterval(2L * 60000L, dataLogging); // Setup the data logging function to be called every 120 seconds (2 mins)
timer.setInterval(10L * 60000L, tweetUptime); // Setup Twitter uptime function to be called every 600 seconds (10 minutes)
void dataLogging()
Serial.println(F("Starting data logging function (Blynk then Thingspeak)"));
Blynk.virtualWrite(V0, rssi); // this sends the WiFi Signal Strenght to Blynk
long uptime = millis() / 60000;
Blynk.virtualWrite(V20, uptime); // this sends the program uptime to Blynk
Serial.println(F("Sending to Blynk - BASEMENT readings"));
Blynk.virtualWrite(V4, baseHum ); // this sends the reading to the Blynk virtual pin
Serial.print(baseHum);
Serial.println("%");
Blynk.virtualWrite(V5, baseTemp); // this sends the reading to the Blynk virtual pin
Serial.print(baseTemp);
Serial.println("'C");
Blynk.virtualWrite(V6, baseDewPoint); // this sends the calculation to the Blynk virtual pin
Serial.print(baseDewPoint);
Blynk.virtualWrite(V19, medianBaseDewPoint); // this sends the calculation to the Blynk virtual pin
Serial.print(F("Basement Dew Point (median):"));
Serial.print(medianBaseDewPoint);
Serial.println(F("Just finished the data logging Blynk section"));
Serial.println(F("Preparing Thingspeak readings"));
if (client.connect(serverThingspeak, 80))
String postStr = apiKeyThingspeak1;
postStr += "&field1=";
postStr += String(roofTemp);
postStr += "&field2=";
postStr += String(roofHum);
postStr += "&field3=";
postStr += String(roofDewPoint);
postStr += "&field4=";
postStr += String(houseTemp);
postStr += "&field5=";
postStr += String(houseHum);
postStr += "&field6=";
postStr += String(houseDewPoint);
postStr += "&field7=";
postStr += String(medianRoofDewPoint);
postStr += "&field8=";
postStr += String(medianHouseDewPoint);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKeyThingspeak1 + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.println(F("Just uploaded to Thingspeak Channel ID: ABDC"));
void tweetUptime()
long uptime = millis() / 60000L;
BLYNK_LOG("Tweeting every 10 minutes ;)");
Blynk.tweet(String("Basement Controller running for ") + uptime + " minutes.");
I’m trying with a WiFi Genuino/Arduino shield, not the ESP8266.
I’m on the same your way… I wanna try out your solution! thanks!
No luck!
I’m not able to use both Blynk and ThungSpeak.
When is planned to integrate ThingSpeak?
this is not very useful for us to help you…
what are you trying to do?
I’m trying to send data to ThingSpeak (while using Blynk)… I’ve tryed with the ThingSpeak library (Arduino) but the sketch reset every way try to upload data, so I’ve tryed to post data with WiFi client but the connectrion to Blynk server is resetted every way try ti post to ThyngSpeak.
This is my sketch…
#define BLYNK_NO_INFO
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
int status = WL_IDLE_STATUS;
WiFiServer server(80);
char auth[] = "43g32g623g623g6g2356g32g";
// Your WiFi credentials
char ssid[] = "2v45gf4gf46fg23gyf536f";
char pass[] = "4b245g346g234g6f236gr";
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String APIKey = "b46g32g632g523g52g"; // enter your channel's Write API Key
const int updateThingSpeakInterval = 20 * 1000; // 20 second interval at which to update ThingSpeak
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
// Initialize Arduino Ethernet Client
WiFiClient client;
//Blynk.begin(auth, ssid, pass);
// Or specify server using one of those commands:
//Blynk.begin(auth, ssid, pass, "cloud.blynk.cc", 8442);
//Blynk.begin(auth, ssid, pass, server_ip, port);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
Blynk.config(auth, IPAddress(192,168,1,110),4882);
// read values from pins and store as strings
String light = String(analogRead(A0), DEC); // read light value
// find temp value
float voltage = analogRead(A1) * (3.3 / 1024); // convert 0-1023 range to 3.3V range
int tempVal = (voltage - 0.5) * 100; // convert voltage to temperature in *C
String temp = String(tempVal);
// Print Update Response to Serial Monitor
if (client.available()) {
char c = client.read();
Serial.print(c);
// Disconnect from ThingSpeak
if (!client.connected() && lastConnected) {
Serial.println("...disconnected");
Serial.println();
client.stop();
// Update ThingSpeak
if (!client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval)) {
updateThingSpeak("field1=" + light + "&field2=" + temp);
Serial.println(light);
Serial.println(temp);
lastConnected = client.connected();
void updateThingSpeak(String tsData) {
if (client.connect(thingSpeakAddress, 80)) {
client.print("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
client.print(tsData.length());
client.print(tsData);
lastConnectionTime = millis();
if (client.connected()) {
Serial.println("Connecting to ThingSpeak...");
Serial.println();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
… and this the terminal of the running sketch…
Attempting to connect to SSID: FRITZ!Box Fon WLAN 7390
IP Address: 192.168.1.152
signal strength (RSSI):-23 dBm
[28478] Blynk v0.3.3
1023
134
[29761] Connecting to 192.168.1.110:4882
H...disconnected
[39782] Connecting to 192.168.1.110:4882
1023
279
[49930] Connecting to 192.168.1.110:4882
so what does it show at your Thingspeak page?
ThingSpeak add data normally, but I lost the connection to Blynk server, so if I increase the data rate the Blynk service are unusable.
so thingspeak data update works?
then which bit of blynk doesn’t work?
Maybe I’m writing in bad english… so sorry for this… it seems I cannot explain.
All works… but all works in a “unstable” way.
As you wrote on your post [quote=“Dave 1829, post:9, topic:379”]
[/quote] … if I upload data to ThingSpeak every seconds, this mean that I have one disconnection and one reconnection in one seconds, so… in this piece of time Blynk cannot work; so this is equivalent to not have Blynk at all. In the same way if I upload to ThingSpeak every 3 seconds, this time is too small to fit disconnection + upload to TS + reconnection to send/receive data to Blynk.
Isn’t a “elegant” solution for me.
So I’ve asked when it’s possible to have a true implementation of ThingSpeak on Blynk; I’ve seen on some post that this are on the roadmap.
For the moment, to bypass the problem I preferred to put a cheaper ESP8266 in I2C handshake with the “main hardware” (Arduino Mega + WiFi shield) that are only charged to send to ThingSpeak until the main hardware are occupied to manage Blynk and all the other services.
In every way, thanks for your time.
well, i guess it works fine for me as i only update Thingspeak every 120 seconds, not every second…
sorry for your troubles…
