[Solved] Getting New Phone - How to Transfer BLYNK Projects
The title of this post pretty much says what I need. How do I transfer all my projects so that they’re functional on my new phone? Step-by-step instructions please.
PS - Thanks a lot for this great product!!!
hi!
i assume you’re using blynk cloud, not local server. in this case, you do not have to transfer any projects, just log in to blynk, all your projects are stored in the blynk cloud.
Install Blynk App
Login with existing info
Enjoy! :slight_smile:
As @wanek said… the server stores it all. You can have multiple devices all accessing the same account if you so need… make a change on one and it will register on all the others. Or simultaneously run multiple different projects (even on the same account) on multiple devices, so as too better experiment with bridging and sharing data between projects.
Outstanding. Thanks for your help all.
@wanek: In the other case it works the same way :wink:
i never used local server, so i can’t declare for this. but thanks for the clue in!
