What do you mean by this screen?
ssl cert and keys are there
How empty fields “are there”? Sorry, I do not understand what you are trying to say.
in my server.properties fields are not empty.
could you please explain.
#by default server uses embedded in jar cert to simplify local server installation.
#WARNNING DO NOT USE THIS CERTIFICATES ON PRODUCTION OR IN WHERE ENVIRNOMENTS REAL SECURITY REQUIRED.
#provide either full path to files either use '.' for specifying current directory. For instance "./myfile.crt"
server.host=
server.ssl.cert=./server_embedded.crt
server.ssl.key=./server_embedded.pem
server.ssl.key.pass=
#Blynk server allows to use 2 hosts for same IP, below properties for second host
server2.host=
server2.ssl.cert=./server_embedded.crt
server2.ssl.key=./server_embedded.pem
server2.ssl.key.pass=
I explained above
did you read what i am typing?
Yes. And I gave you an answer of what you should do.
ok
where can i find a tutorial ?
as me and many others knows nothing in java.
Here you can find many requests.
You just have outdated configs. That’s all. It is not related to java.
More Help is needed
Continuing the discussion from Local Blynk Server Tutorial:
WARNING: You should have password for certificate. Certificates without passwords are not accepted.
openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
can you tell us how to?
@Ze_Pico from memory it should ask you for a password as part of the process when you issue the command.
This was fixed and password is not required anymore. However in case of those instruction you should be promted with password.
@Costas
Hi Costas
yes. but it don’t accept any entry. " only the enter key"
C:\My_Server>openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
Enter Encryption Password:
Verifying - Enter Encryption Password:
Verify failure
can you try it for me.
Exception in thread "main" java.lang.RuntimeException: File does not contain valid private key: .\server_embedded.pem
is there a new server version?
Did you try what @Dmitriy said? Run it without the certs. If that works, you can go on to generating certificates. On Windows you may need to enter the full path and use different \ or / because the file system works differently from LInux.
From the image that i can see, you have labelled your server file-name wrong. last server 0.23.3 was with .jar extension. 0.23.5 is with “.joe” extension. First try changing the file name.
yes, I named it like this so it is not detected by my StartBlynkServer.cmd to use ver 0.23.3 last working server for me
