Hello, I have a question about RPi Cam Web Interface.
I follow the instructions of Sparkfun for Setting Up the Pi Zero Wireless Pan-Tilt Camera, in there they talk about the RPi cam, in fact it creates an ip address, and it sees like this
What I want to know is if this ip address can be using in the Blynk app in the section video streaming, and why I need a virtual pin (or how I can configure in Raspberry pi?)
About 2 years ago I used the Blynk with my Particle and I loved it, but now I’m new using the Raspberry pi (I have raspberry pi zero w, but I read I can use the option Raspberry pi 3 and it can works).
The RPi needs to send a proper video stream of some sort… and that is the URL you can use, it can NOT use an IP leading to a web page for control.
For Blynk control you would need Blynk code on the RPi (aka NodeJS perhaps) and then find a way to control the pan & tilt with that. I have done something along that lines here… just haven’t gotten around to the video part
The vPin is for “remotely” changing the URL in the widget… e.g. from your sketch…
Thank you so much for the answer, I will try to work on… NodeJS.
In the past I only have worked with Arduino, Particle Photon and SparkFun Blynk Board (I mean, I’ve only used IDE), so this is so new for me.
I find it difficult to handle the fact that it is an operating system, but I can also program to use the pins, etc.
