Does anyone have a step by step install to get this working?
I’ve tried all using
and I still get the
root@raspberrypi:/home/pi/blynk-library/linux# sudo NODE_PATH=/usr/local/lib/node_modules/blynk-library node ./blynk.temp.js
module.js:338
throw err;
Error: Cannot find module ‘blynk-library’
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object. (/home/pi/blynk-library/linux/blynk.temp.js:1:78)
at Module._compile (module.js:460:26)
at Object.Module._extensions…js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:501:10)
Hi im having the same problem,i tried sudo NODE_PATH=/usr/local/lib/node_modules/ node ./blynk.temp.js
and i still get module.js:340
throw err;
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/home/pi/blynk-sensor-test.js:1:78)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
