i have set to start at 8:00 PM and stop at 8:00AM but not found…in 8.00AM relay dont stop…if i reset NODEMCU at 8:01AM…light turn OFF…in 8:00PM dont start…but if i reset device…light turn on…what is a problem?
PS : i have test start at 8.00PM and stop at 8:01 PM and system work good!
Which pin is the relay hooked up to as resetting the NODEMCU is probably sending the pins high / low and activating the relay? Is the relay active high or low and are you using a virtual pin tied to a digital pin?
Just to be clear should the light come on at 8PM and go off at 8AM or is it the other way around?
