Is there any service/App that would notify me whenever my phone is full charged?
I want to make a application related to this using blynk.
mmm really interresting project, i have a new phone samsung s6 the battery is gone coz i leave it in the charger over night. so now i charged before i sleep, it would be good in you can make a switch plugged to the wall plug that switch off once your phone is fully charger and it switch on once your battery is 95 percent… let make it ? iam quite new so i will give u a headache.
You can use Tasker for this purpose. There’s a really good tutorial made by @bobli
After that you can activate a Pin IF the Battery is between 95 and 100 % for instance.
This Pin would disconnect the power supply using a Relay.
Yep, it is possible for Android
I have figured it out. Will post after completing the project.
Tasker is not free, I have found a free alternative.
How do I get the data?
Sorry, if you thought that it is possible now, it was an answer to @Pavel that implementation of such widget is possible.
