What’s new :
- New Widget - Step Control;
- “Keep screen on” feature wasn’t working fix;
- Gauge now supports formatting as labeled display;
You need latest server to use this feature.
What’s new :
A good one! Can You think about handling "hold the button"action to fast forward/backward the value?
And that is why I “LOVE” Blynk
always under development, constantly improving… Guess one day gauge will be improved too, so will wait patiently
That’s pretty great, thanks guys. This kind of widget might work well as a jog wheel mode too (with speed dependent increment). Kind of like a 1x2 ten turn potentiometer.
Nice. I like the step increment definition. Is there any thoughts around extending the step increment to the slider. I would find that useful as the slider to me is cosmetically nice.
thanks for the reminder… ![]()
Oh man another Android release. Apple is really slowing me down!
I went looking, when answering someone’s question, but couldn’t find these widgets listed in the DOCS… or am I mislead again? ![]()
@Dmytro does this send value instantly or is there a delay?
I’m thinking like after 1-2 seconds of the last button press -> value is updated to the server, this should at least be a setting, delayed send.
I could think of using this as a means of calibration for example a voltage dividing circuit for battery voltage. However having it send values on every press, I’m a bit worried of flooding the esp module.
But maybe it’s just my lack of experience talking ^^
All button/switch/control widgets send out the data as pushed, moved or released (depending on if send on release is enabled). If you want delays, then setup a timer in the code. Generally not a bad idea anyhow as YES, you can get flood results with any rapid controller usage.
Good catch. I’ll fix soon.
@Dmytro Also, I just discovered that even with a range of 0-255, a step of 15 (or really anything) and directly controlling a PWM Digital pin… instead of getting a range of intensity on an LED, I get OFF with 0 and ON with any other value. Using a virtual pin with code passing the value to the PWM pin gets desired results. This is on either the H or V widget
