Nice
but IOS IOS IOS pls
Active iOS phase will start from 1 december. We will start from bug fixes (~2 weeks). After that we will start with webhook, video widgets.
Ok thanks! But GPS and other native sensors on IOS is priority for me. Thanks!
Hello! Just discovered the magic of Blynk and I have to say I am more than impressed!
Thank you all for your efforts! Great job guys!
I have an observation to make regarding the homescreen button widget. I am trying to use it in push-button mode and need to actually press it for about 1 second, in order to buzz me in through the door. Maybe, this somehow is resolved but I have been reading all morning and have been unable to find a solution to my issue. I am using samsung android phone, and when I try to hold down the homescreen button, the phone goes into “moving widgets around mode” making me unable to keep pressed the homescreen button. Is there a way around this, like set the button to send the signal “1” for an amount of time (like an 1 second pulse), every time I instantly press it? Without having to wirte relevant code on hardware side…
Thank you and keep up the wonderful work!
@Greek_Geek you need to code the 1 second event and then use the Homescreen button widget to trigger the event.
great - look forward to it - hope the Terminal widget issue is addressed in first release
@Greek_Geek hello. this is not possible due to Android system limitations. However you can go with workaround proposed by @Costas.
I love the joystick widget, really cool for RC things.
It will be lovely if You could make the joystick widget autoreturn feature work (toggle-able) per axis, just like left joystick of mode 2 RC Transmitter (the Y-axis, throttle would be free to move, but X-axis, rudder always centered).
Thank You.
