Hello Everyone!
I’m on a ambilight project for my Tv. I wanted to use blynk to control my led strip over wifi.
I have a setting on my strip code which defines the number of leds in the strip.
#define LEDCOUNT 50
if the led count is not so many like 50 or 75. Everything is fine, my program works like a charm.
But if increase the led count to 173 (real led count in my project), blynk starts to fail. I get “Failed to disable echo” or “Failed to set STA mode” error. If i reduce the led count to 50 after that, everything works again.
According to my research on the adafruit website, led count effects the ram usage of the code. I am not sure the problem is related to ram or whatever!
You can see my code below. If anyone has an idea regarding to my led count issue, it would be great to hear!
Thanks in advance.
Each NeoPixel requires about 3 bytes of RAM. This doesn’t sound like very much, but when you start using dozens or even hundreds of pixels, and consider that the mainstream Arduino Uno only has 2 kilobytes of RAM (often much less after other libraries stake their claim), this can be a real problem!
link!
#include <Adafruit_NeoPixel.h>
#include <ESP8266_Lib.h>
#include <DHT.h>
/* Wifi Settings */
char auth[] = "6333a7e3c98d4ed2ba15618c8e6fe48f"; //for blynk cloud
//char auth[] = " 385beae3065847bc14bea96ef16ec522"; // local rasp3 openelecv6.03
char ssid[] = "30_M_BALIKESIR";
char pass[] = "bilmiyorum";
#define ESP8266_BAUD 9600 // Your ESP8266 baud rate:
/* DHT Settings */
#define DHTPIN 5 // What digital pin we're connected to
/* Hyperion - Ambilight Settings */
#define STARTCOLOR 0xffffff // LED colors at start
#define BLACK 0x000000 // LED color BLACK
#define DATAPIN 6 // Datapin
#define LEDCOUNT 50 // Number of LEDs used for boblight 173
// LEDCOUNT value is local value in Arduino sketch, for hyperion it doesn't matter it sends prefx characters according to hyperion config
#define SHOWDELAY 200 // Delay in micro seconds before showing default 200
#define BAUDRATE 9600// Serial port speed, 460800 tested with Arduino Uno R3 23400 za MEGA, 115200 nano
int BRIGHTNESS = 70; // Max. brightness in %
//Hyperion sends prefix characters based on number of LEDs in config file
// e.g. for 181 LEDs it will send 0xB4 and cheksum 0xE1
// keep in mind if you are using boblight config to calculate prefix that Boblight counts diodes from 1 and Hyperion from 0
// if you have problems try +1 or -1 diodes when generating prefix characters
// values to save some time: 178 B1 E4, 180 B3E6, 181 B4E1, 182 B5E0
//hyperion code
//_ledBuffer[3] = ((ledValues.size() - 1) >> 8) & 0xFF; // LED count high byte
// _ledBuffer[4] = (ledValues.size() - 1) & 0xFF; // LED count low byte
// _ledBuffer[5] = _ledBuffer[3] ^ _ledBuffer[4] ^ 0x55; // Checksum
const char prefix[] = {0x41, 0x64, 0x61, 0x00, 0xB4, 0xE1}; // Start prefix ADA
char buffer[sizeof(prefix)]; // Temp buffer for receiving prefix data
// Init LED strand, WS2811/WS2912 specific
// These might work for other configurations:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDCOUNT, DATAPIN, NEO_GRB + NEO_KHZ800);
/* Variables */
ESP8266 wifi(&EspSerial);
DHT dht(DHTPIN, DHTTYPE);
WidgetLED led8(V8);
int state; // Define current state
#define STATE_WAITING 1 // - Waiting for prefix
#define STATE_DO_PREFIX 2 // - Processing prefix
#define STATE_DO_DATA 3 // - Handling incoming LED colors
int readSerial; // Read Serial data (1)
int currentLED; // Needed for assigning the color to the right LED
/* wifi */
Serial.begin(BAUDRATE); // Init serial speed
delay(50);
// Set ESP8266 baud rate
delay(50);
Blynk.begin(auth, wifi, ssid, pass); //for blynk cloud
Serial.println("3");
//Blynk.begin(auth, wifi, ssid, pass, "192.168.1.119"); // local rasp3 openelecv6.03
dht.begin();
Serial.println("4");
/* strip */
state = STATE_WAITING; // Initial state: Waiting for prefix
strip.begin(); // Init LED strand, set all black, then all to startcolor
strip.setBrightness( (255 / 100) * BRIGHTNESS );
setAllLEDs(BLACK, 0);
setAllLEDs(STARTCOLOR, 5);
switch(state)
case STATE_WAITING: // *** Waiting for prefix ***
if( Serial.available()>0 )
readSerial = Serial.read(); // Read one character
if ( readSerial == prefix[0] ) // if this character is 1st prefix char
{ state = STATE_DO_PREFIX; } // then set state to handle prefix
break;
case STATE_DO_PREFIX: // *** Processing Prefix ***
if( Serial.available() > sizeof(prefix) - 2 )
Serial.readBytes(buffer, sizeof(prefix) - 1);
for( int Counter = 0; Counter < sizeof(prefix) - 1; Counter++)
if( buffer[Counter] == prefix[Counter+1] )
state = STATE_DO_DATA; // Received character is in prefix, continue
currentLED = 0; // Set current LED to the first one
state = STATE_WAITING; // Crap, one of the received chars is NOT in the prefix
break; // Exit, to go back to waiting for the prefix
} // end if buffer
} // end for Counter
} // end if Serial
break;
case STATE_DO_DATA: // *** Process incoming color data ***
if( Serial.available() > 2 ) // if we receive more than 2 chars
Serial.readBytes( buffer, 3 ); // Abuse buffer to temp store 3 charaters
strip.setPixelColor( currentLED++, buffer[0], buffer[1], buffer[2]); // and assing to LEDs
if( currentLED > LEDCOUNT ) // Reached the last LED? Display it!
strip.show(); // Make colors visible
delayMicroseconds(SHOWDELAY); // Wait a few micro seconds
state = STATE_WAITING; // Reset to waiting ...
currentLED = 0; // and go to LED one
break; // and exit ... and do it all over again
break;
} // switch(state)
/* Functions */
BLYNK_WRITE(V0)
BRIGHTNESS = param.asInt(); // assigning incoming value from pin V0 to a variable
strip.begin();
strip.show();
Serial.print("V0 Slider value is: ");
Serial.println(BRIGHTNESS);
BLYNK_WRITE(V1) { //zeRGGa data from widget
int r = param[0].asInt();
int g = param[1].asInt();
int b = param[2].asInt();
colorAll(strip.Color(r, g, b), 1);
strip.show();
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
void setAllLEDs(uint32_t color, int wait)
for ( int Counter=0; Counter < LEDCOUNT; Counter++ ) // For each LED
strip.setPixelColor( Counter, color ); // .. set the color
if( wait > 0 ) // if a wait time was set then
strip.show(); // Show the LED color
delay(wait); // and wait before we do the next LED
} // if wait
} // for Counter
strip.show(); // Show all LEDs
} // setAllLEDs
void colorAll(uint32_t c, uint8_t wait) {
uint16_t i;
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(1);
