Need some help with battery reading
Need some help with battery reading. I am monitoring a 12v leisure battery for a greenhouse project. I have connected a 1M ohm resistor in series with pin A0 on the Wemos D1 mini. On the blynk app I have two value displays, one has pin A0 assigned and the other has pin V0 assigned. I have a reading on A0 (raw ADC value) but nothing on V0. Any help would be great. Code below.
#include <DHT.h>
char auth[] = "***************************************";
char ssid[] = "*************";
char pass[] = "**************";
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  int hAsInt = int(h); // converts to int removing unessisary decimal points
  int tAsInt = int(t);
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
// Simple monitoring of internal voltage levels:
void VCCInput() {
  //Blynk.virtualWrite(V0, ESP.getVcc() * 0.001);
  Blynk.virtualWrite(V0, analogRead(A0)*0.0145);  // ADC range up to 14.8v
  dht.begin();
First off, it is always best to start your own topic, not add onto others. I have moved and or removed your posts accordingly.
That is becasue you are not doing anything to call your VCCInput() function.
I recommend another non-coinciding timer (E.g. 1035L), or merge the battery commands into existing DHT timer function.
Apologies I’m fairly new to posting. I added timer.setInterval(2000L, VCCInput); and that worked
Thanks for the help Gunner
It will not matter much with only two little timers… but best to lern the habbit sooner. By non-coinciding I meant something offset enough that both timers (which start counting at the same time) will not try to run their functions at the same time every two seconds.
Ah, got it. New to the programming also. “timer.setInterval(1035L, VCCInput);”
If you wanted a 2 second reading then offsetting by 35ms would work just as well there - 2035L
1 - second timer
1 - second timer, followed 35ms later by 2 second timer
1 - second timer
… and so on.
