Make Multiple input from Virtual PIN
heloo, first i am sorry ifmy english is bad.
i have project using arduino uno with esp8266 and blynk for controling relay with timer in each relay, i using menu widget for chose from relay 1-4 and after that, i can set timer in each relay and if timer is active, then will triger led widget to turn on, but i new in arduino but i know little bit. First i use blynk_write(), but this can’t use multiple input vPin, so can i use blynk_write_default() for using multiple vpin??
for clearly this my code for set timer menu :
BLYNK_WRITE_DEFAULT() {
  int vPin = request.pin;
  if (vPin == 9){
    switch(param.asInt())
      case 1:
        if (EEPROM.read(7)==0) { Blynk.virtualWrite(V11,0); led1.on(); }
        else { Blynk.virtualWrite(V11,1); led1.off(); }
        if (vPin == 11) {
          if (param.asInt()==0) {
             led1.on();EEPROM.write(7, 0);
             TimeInputParam t(param);
             EEPROM.write(13,t.getStartHour());
             EEPROM.write(14,t.getStartMinute());
             EEPROM.write(15,t.getStopHour());
             EEPROM.write(16,t.getStopMinute());
             Serial.print(TR1a1);
             Serial.println(TR1a2);
          else {
            led1.off();EEPROM.write(7, 1);
            EEPROM.write(13,00);
            EEPROM.write(14,00);
            EEPROM.write(15,00);
            EEPROM.write(16,00);
      break;
      case 2:
        if (EEPROM.read(8)==0){Blynk.virtualWrite(V11,0); led2.on();}
        else {Blynk.virtualWrite(V11,1); led2.off();}
        if (vPin == 11) {
             led2.on();EEPROM.write(8, 0);
             EEPROM.write(17,t.getStartHour());
             EEPROM.write(18,t.getStartMinute());
             EEPROM.write(19,t.getStopHour());
             EEPROM.write(20,t.getStopMinute());
          else {
            led2.off();EEPROM.write(8, 1);
            EEPROM.write(17,00);
            EEPROM.write(18,00);
            EEPROM.write(19,00);
            EEPROM.write(20,00);;
      break;
      case 3:
        if (EEPROM.read(9)==0){Blynk.virtualWrite(V11,0); led3.on();}
        else {Blynk.virtualWrite(V11,1); led3.off();}
        if (vPin == 11) {
             led3.on();EEPROM.write(9, 0);
             EEPROM.write(21,t.getStartHour());
             EEPROM.write(22,t.getStartMinute());
             EEPROM.write(23,t.getStopHour());
             EEPROM.write(24,t.getStopMinute());
          else {
            led3.off();EEPROM.write(9, 1);
            EEPROM.write(21,00);
            EEPROM.write(22,00);
            EEPROM.write(23,00);
            EEPROM.write(24,00);
      break;
      case 4:
        if (EEPROM.read(10)==0){Blynk.virtualWrite(V11,0); led4.on();}
        else {Blynk.virtualWrite(V11,1); led4.off();}
        if (vPin == 11) {
             led4.on();EEPROM.write(10, 0);
             EEPROM.write(25,t.getStartHour());
             EEPROM.write(26,t.getStartMinute());
             EEPROM.write(27,t.getStopHour());
             EEPROM.write(28,t.getStopMinute());
          else {
            led4.off();EEPROM.write(10, 1);
            EEPROM.write(25,00);
            EEPROM.write(26,00);
            EEPROM.write(27,00);
            EEPROM.write(28,00);
      break;
      case 5:
        if (EEPROM.read(11)==0){Blynk.virtualWrite(V11,0); led5.on();}
        else {Blynk.virtualWrite(V11,1); led5.off();}
        if (vPin == 11) {
             led5.on();EEPROM.write(11, 0);
             EEPROM.write(29,t.getStartHour());
             EEPROM.write(30,t.getStartMinute());
             EEPROM.write(31,t.getStopHour());
             EEPROM.write(32,t.getStopMinute());
          else {
            led5.off();EEPROM.write(11, 1);
            EEPROM.write(29,00);
            EEPROM.write(30,00);
            EEPROM.write(31,00);
            EEPROM.write(32,00);
      break;
      case 6:
        if (EEPROM.read(11)==0){Blynk.virtualWrite(V11,0); led6.on();}
        else {Blynk.virtualWrite(V11,1); led6.off();}
        if (vPin == 11) {
             led6.on();EEPROM.write(12, 0);
             EEPROM.write(33,t.getStartHour());
             EEPROM.write(34,t.getStartMinute());
             EEPROM.write(35,t.getStopHour());
             EEPROM.write(36,t.getStopMinute());
          else {
            led6.off();EEPROM.write(12, 1);
            EEPROM.write(33,00);
            EEPROM.write(34,00);
            EEPROM.write(35,00);
            EEPROM.write(36,00);
      break;
after upload to my hardware, this code not working and not give some feedback to my app, even just turn on led widget, so i think the problem is in my code.
and this is my code for triger the relay to turn on/off, sory if this code lot of false code (i am new in this) :
void TimerRelay(){
 String RTC = rtc.getHour()+rtc.getMinute();
 String R1on = TR1a1+TR1a2; String R1off = TR1b1+TR1b2; //tr1a1 for start hour, tr1a2 for  start minute, tr1b1 for stophour
 String R2on = TR2a1+TR2a2; String R2off = TR2b1+TR2b2;
 String R3on = TR3a1+TR3a2; String R3off = TR3b1+TR3b2;
 String R4on = TR4a1+TR4a2; String R4off = TR4b1+TR4b2;
 String R5on = TR5a1+TR5a2; String R5off = TR5b1+TR5b2;
 String R6on = TR6a1+TR6a2; String R6off = TR6b1+TR6b2;
  if(EEPROM.read(7==0)){
    if(RTC==R1on){digitalWrite(relay1, LOW);Serial.println("Relay 1 ON via Timer");
    EEPROM.write(1, 0);}
    if(RTC==R1off){digitalWrite(relay1, HIGH);Serial.println("Relay 1 OFF via Timer");
    EEPROM.write(1, 1);}
  if(EEPROM.read(8==0)){
    if(RTC==R2on){digitalWrite(relay2, LOW);Serial.println("Relay 2 ON via Timer");
    EEPROM.write(2, 0);}
    if(RTC==R2off){digitalWrite(relay2, HIGH);Serial.println("Relay 2 OFF via Timer");
    EEPROM.write(2, 1);}
  if(EEPROM.read(9==0)){
    if(RTC==R3on){digitalWrite(relay3, LOW);Serial.println("Relay 3 ON via Timer");
    EEPROM.write(3, 0);}
    if(RTC==R3off){digitalWrite(relay3, HIGH);Serial.println("Relay 3 OFF via Timer");
    EEPROM.write(3, 1);}
  if(EEPROM.read(10==0)){
    if(RTC==R4on){digitalWrite(relay4, LOW);Serial.println("Relay 4 ON via Timer");
    EEPROM.write(4, 0);}
    if(RTC==R4off){digitalWrite(relay4, HIGH);Serial.println("Relay 4 OFF via Timer");
    EEPROM.write(4, 1);}
   if(EEPROM.read(11==0)){
    if(RTC==R5on){digitalWrite(relay5, LOW);Serial.println("Relay 5 ON via Timer");
    EEPROM.write(5, 0);}
    if(RTC==R5off){digitalWrite(relay5, HIGH);Serial.println("Relay 5 OFF via Timer");
    EEPROM.write(5, 1);}
   if(EEPROM.read(12==0)){
    if(RTC==R6on){digitalWrite(relay6, LOW);Serial.println("Relay 6 ON via Timer");
    EEPROM.write(6, 0);}
    if(RTC==R6off){digitalWrite(relay6, HIGH);Serial.println("Relay 6 OFF via Timer");
    EEPROM.write(6, 1);}
maybe you can help me for fix this,
so thanks friend :slight_smile:
Hey welcome to the community!
So your code is incorrect, but easy to remedy.
You need to fix your BLYNK_WRITE function because im not sure where you got request.pin from?
Edit: re-read your question… update coming shortly
Edit-Edit: okay looking at your code… I think you’re quite confused about how to do this.
Here is a basic example of how multiple BLYNK_WRITE works…
BLYNK_WRITE(V10) { // V10 is the virtual pin that toggles this operation
  if (param.asInt()) { // check if the widget data is true. this would be an int value if using a slider, but 0/1 logic applies
    // do something if HIGH/1/TRUE
    // do something if LOW/0/FALSE
BLYNK_WRITE(V11) { // V11 is the virtual pin that toggles this operation
BLYNK_WRITE(V12) { // V12 is the virtual pin that toggles this operation
So taking a bit of your example, this would toggle when you assign a widget to V11 and make an action… but press a button or move a slider. param.asInt() is the value from a slider, or 0/1 is a button.
BLYNK_WRITE(V11) {
    led1.off();
    EEPROM.write(7, 1);
    EEPROM.write(13, 00);
    EEPROM.write(14, 00);
    EEPROM.write(15, 00);
    EEPROM.write(16, 00);
    led1.on();
    EEPROM.write(7, 0);
    TimeInputParam t(param.asInt()); // must use param.asInt()
    EEPROM.write(13, t.getStartHour());
    EEPROM.write(14, t.getStartMinute());
    EEPROM.write(15, t.getStopHour());
    EEPROM.write(16, t.getStopMinute());
This is used when overriding the default version BLYNK_WRITE_DEFAULT to know what virtual pin got triggered :slight_smile:
You should really rethink all those writes to EEPROM, you will burn through it pretty quickly depending on use of course.
I think I read somewhere that the EEPROM on the esp8266 can handle about 100 000 erase/writes per bit.
Edit: Might not be the worst for your current sketch, I don’t know to be honest, but if you start writing 100s/1000s of times per day it will tear eventually. Best is to avoid learning this practice in my opinion :stuck_out_tongue:
Thanks jamin for your answer and give some idea, today i make change on my code, so not use BLYNK_WRITE_DEFAULT(), and Use BLYNK_WRITE(), i will post my new code
Yes i know EEPROM have limit in read/write data, and i save data in EEPROM from arduino. The purpose i use this EEPROM is becasue i want the hardware running the last state from relay and timer from memory, so if some time the device turn off because power problem, this device can read from EEPROM and running the last state without conect to internet for sync to server. Maybe i should use eeprom.update() so the program not always write data to memory. Correct if i am wrong :slight_smile:
It should suffice that you read eeprom and only save if memory doesn’t match current value
And here the full sketch after trial and error, the result for compiling is done and no error, but not already upload to hardware. but if you found some problem with my code its will helpfull for me
//#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
#include <EEPROM.h>
#include <EEPROMAnything.h>
#include <DS1302.h>
#include <DHT.h>
#define ESP8266_BAUD 9600
SoftwareSerial EspSerial(13,12); // RX, TX
ESP8266 wifi(&EspSerial);
DS1302 rtc(A1, A2, A3); // Set pins:  CE/RST,IO/DATA,CLK
Time t = rtc.getTime();
DHT dht;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx"; //token dari blynk
char ssid[] = "xxxxxxxxxx";                            // nama akses point
char pass[] = "xxxxxxxxxxxx";                         // password akses point
//inisialisasi port relay
const int relay1 =  3; const int relay2 =  4;
const int relay3 =  5; const int relay4 =  6;
char Relay,jamStart,menitStart,jamStop,menitStop,statusT;
WidgetLED led1(V12); WidgetLED led2(V13);
WidgetLED led3(V14); WidgetLED led4(V15);
WidgetLED led5(V16); WidgetLED led6(V17);
//inisialisasi memori
byte State1 = EEPROM.read(1); byte State2 = EEPROM.read(2);
byte State3 = EEPROM.read(3); byte State4 = EEPROM.read(4);
byte State5 = EEPROM.read(5); byte State6 = EEPROM.read(6);
struct config_t
  char jamStart,menitStart,jamStop,menitStop,statusT;
} cfg;
int startTimer = (jamStart*60+menitStart);
int stopTimer = (jamStop*60+menitStop);
int rtcNow = (t.hour*60+t.min);
byte timerRelay1 = EEPROM_readAnything(7,cfg);
byte timerRelay2 = EEPROM_readAnything(8,cfg);
byte timerRelay3 = EEPROM_readAnything(9,cfg);
byte timerRelay4 = EEPROM_readAnything(10,cfg);
byte timerRelay5 = EEPROM_readAnything(11,cfg);
byte timerRelay6 = EEPROM_readAnything(12,cfg);
  // Set ESP8266 baud rate
  dht.setup(2);
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  digitalWrite(relay1,HIGH);
  digitalWrite(relay2,HIGH);
  digitalWrite(relay3,HIGH);
  digitalWrite(relay4,HIGH);
  Serial.println (F("Perangkat menyala...")); delay(1000);
  // membaca status terakhir relay;
  Serial.println (F("Cek status terakhir...")); delay(1000);
  ReadEEPROM (); delay(2000);
  Serial.print(F("menghubungkan ke SSID: "));
  Serial.println(ssid);
  //memulai koneksi ke apn
  Serial.print (F("terhubung ke SSID "));
  Serial.println(ssid); delay(2000);
  //update status button ke server
  Serial.println (F("update status relay ke server..."));
  writeEEPROMapp ();
  Serial.println (F("update berhasil\n"));
  timer.setInterval(5000L, sendSensor);
void sendSensor(){
  int h = dht.getHumidity();
  int t = dht.getTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h) || isnan(t)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  //menampilkan data pada terminal monitor
  Serial.print(F("update suhu: "));
  Serial.print(t);
  Serial.println(F("C"));
  Serial.print(F("update humidity: "));
  Serial.print(h);
  Serial.println(F("%\n"));
BLYNK_WRITE(V1){
  if(param.asInt()==0){
     digitalWrite(relay1,LOW); Serial.println(F("Relay 1 ON"));
     EEPROM.update(1, 0);}
  else{
     digitalWrite(relay1,HIGH); Serial.println(F("Relay 1 OFF"));
     EEPROM.update(1, 1);}
BLYNK_WRITE(V2){
     digitalWrite(relay2,LOW); Serial.println(F("Relay 2 ON"));
     EEPROM.update(2, 0);}
  else{
     digitalWrite(relay2,HIGH); Serial.println(F("Relay 2 OFF"));
     EEPROM.update(2, 1);}
BLYNK_WRITE(V3){
     digitalWrite(relay3,LOW); Serial.println(F("Relay 3 ON"));
     EEPROM.update(3, 0);}
  else{
     digitalWrite(relay3,HIGH); Serial.println(F("Relay 3 OFF"));
     EEPROM.update(3, 1);}
BLYNK_WRITE(V4){
     digitalWrite(relay4,LOW); Serial.println(F("Relay 4 ON"));
     EEPROM.update(4, 0);}
  else{
     digitalWrite(relay4,HIGH); Serial.println(F("Relay 4 OFF"));
     EEPROM.update(4, 1);}
BLYNK_WRITE(V9) {
  switch (param.asInt()) {
    case 1: Relay = 1; break;
    case 2: Relay = 2; break;
    case 3: Relay = 3; break;
    case 4: Relay = 4; break;
    case 5: Relay = 5; break;
    case 6: Relay = 6; break;
BLYNK_WRITE(V10) {
  jamStart = t.getStartHour(); menitStart = t.getStartMinute();
  jamStop = t.getStopHour();   menitStop = t.getStopMinute();
BLYNK_WRITE(V11) {
  if (Relay == 1) {
    if (param.asInt() && statusT==0){
      statusT = (1);
      EEPROM_writeAnything(7, cfg);
      led1.on();
      Serial.println(String(" Timer Relay 1 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
      + "\nStop: " + jamStart + ":" + menitStart);
    else {
      resetTime();
      led1.off();
      Serial.println(F(" Timer Relay 1 MATI!! "));
  if (Relay == 2) {
      statusT = (1);
      EEPROM_writeAnything(8, cfg);
      led2.on();
      Serial.println(String(" Timer Relay 2 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
    else {
      resetTime();
      led2.off();
      Serial.println(F(" Timer Relay 2 MATI!! "));
  if (Relay == 3) {
      statusT = (1);
      EEPROM_writeAnything(9, cfg);
      led3.on();
      Serial.println(String(" Timer Relay 3 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
    else {
      resetTime();
      led3.off();
      Serial.println(F(" Timer Relay 3 MATI!! "));
  if (Relay == 4) {
      statusT = (1);
      EEPROM_writeAnything(10, cfg);
      led4.on();
      Serial.println(String(" Timer Relay 4 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
    else {
      resetTime();
      led4.off();
      Serial.println(F(" Timer Relay 4 MATI!! "));
  if (Relay == 5) {
      statusT = (1);
      EEPROM_writeAnything(11, cfg);
      led5.on();
      Serial.println(String(" Timer Relay 5 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
    else {
      resetTime();
      led5.off();
      Serial.println(F(" Timer Relay 5 MATI!! "));
  if (Relay == 6) {
      statusT = (1);
      EEPROM_writeAnything(12, cfg);
      led6.on();
      Serial.println(String(" Timer Relay 6 AKTIF!! \nStart: ")+ jamStart + ":" + menitStart
    else {
      resetTime();
      led6.off();
      Serial.println(F(" Timer Relay 6 MATI!! "));
void resetTime(){
  jamStart = (00); menitStart = (00);
  jamStop = (00);  menitStop = (00);
  statusT =(00);
void timerRelay() {
  if (timerRelay1) {
    if(statusT==1 && rtcNow == startTimer) {
      digitalWrite(relay1,LOW); Serial.println(F("Relay 1 ON with Timer"));
    else if (statusT==1 && rtcNow == stopTimer) {
      digitalWrite(relay1,HIGH); Serial.println(F("Relay 1 OFF  with Timer"));
  if (timerRelay2) {
      digitalWrite(relay2,LOW); Serial.println(F("Relay 2 ON with Timer"));
      digitalWrite(relay2,HIGH); Serial.println(F("Relay 2 OFF  with Timer"));
  if (timerRelay3) {
      digitalWrite(relay3,LOW); Serial.println(F("Relay 3 ON with Timer"));
  if (timerRelay4) {
      digitalWrite(relay4,LOW); Serial.println(F("Relay 4 ON with Timer"));
void ReadEEPROM (){
  Serial.print(F("Posisi Terakhir relay1 = "));
  if(State1==0){digitalWrite(relay1,LOW); Serial.println(F("ON"));}
  else {digitalWrite(relay1,HIGH); Serial.println(F("OFF"));}
  Serial.print(F("Posisi Terakhir relay2 = "));
  if(State2==0){digitalWrite(relay2,LOW); Serial.println(F("ON"));}
  else {digitalWrite(relay2,HIGH); Serial.println(F("OFF"));}
  Serial.print(F("Posisi Terakhir relay3 = "));
  if(State3==0){digitalWrite(relay3,LOW); Serial.println(F("ON"));}
  else {digitalWrite(relay3,HIGH); Serial.println(F("OFF"));}
  Serial.print(F("Posisi Terakhir relay4 = "));
  if(State4==0){digitalWrite(relay4,LOW); Serial.println(F("ON"));}
  else {digitalWrite(relay4,HIGH); Serial.println(F("OFF\n"));}
  //digitalWrite(relay5,State5);
  //Serial.print(F("Posisi Terakhir relay5 = "));
  //if(State5==0){Serial.println("ON");} else {Serial.println("OFF");}
  //digitalWrite(relay6,State6);
  //Serial.print(F("Posisi Terakhir relay6 = "));
  //if(State6==0){Serial.println("ON");} else {Serial.println("OFF");}
void writeEEPROMapp (){
  if(State1==0){Blynk.virtualWrite(V1,0);}
  else {Blynk.virtualWrite(V1,1);}
  if(State2==0){Blynk.virtualWrite(V2,0);}
  else {Blynk.virtualWrite(V2,1);}
  if(State3==0){Blynk.virtualWrite(V3,0);}
  else {Blynk.virtualWrite(V3,1);}
  if(State4==0){Blynk.virtualWrite(V4,0);}
  else {Blynk.virtualWrite(V4,1);}
  timerRelay();
