Issue on Cloud Blynk Server
Hi all,
Just recently I have problem connecting to Cloud Blynk Server (I suspect after recent update on the server, but this is just my thought)
This is my sketch that several days ago has no issue with Cloud Server and I haven’t change any wiring on my NodeMCU:
#include <TimeLib.h>
#include <DHT.h>
#include <NTPtimeESP.h>
// -- NodeMCU PIN to ESP8266 ESP-12 Pinout
#define LDRPIN A0 // ADC Pin for LDR Sensor
#define D1 5  // LED 1 (Yellow)
#define D2 4  // LED 4 (White)
#define D3 0  // LED 2 (Green)
#define SystemLED 2 // GPIO-2 --> D4
#define D5 14 // LED 3 (Red)
#define DHTPIN 12 //  GPIO-12 --> D6
#define D7 13
#define D8 15
#define D9 3
#define D10 1
// -- Blynk Virtual PIN definition
#define VDisplayTemp_Pin V10
#define VDisplayHumid_Pin V11
#define VDisplayLDR_Pin V12
#define VDisplayUptime_Pin V20
#define VDisplayNetConnect_Pin V21
#define VDisplayNetConnectUp_Pin V22
#define VDisplayDate_Time V23
#define VTimeInput1 V28
#define VTimeInput2 V29
#define VTimeInput3 V30
#define VTimeInput4 V27
#define VButton1_Pin V31
#define VButton2_Pin V32 // with Timer
#define VButton3_Pin V33
#define VButton5_Pin V35
#define VButtonTimer1_Pin V36
#define VButtonTimer3_Pin V37
#define VButtonTimer5_Pin V38
#define VButtonTimer2_Pin V39
#define VLEDblink_Pin V3
#define VLEDDHT11_Pin V4
//#define VLED1_Pin V41
//#define VLED2_Pin V42
//#define VLED3_Pin V43
//#define VLED5_Pin V45
const char auth[] = "xxxxxxxxxxxxxxxxxxxx"; //insert here your token generated by Blynk
const char ssid[] = "Camar-24";
const char pass[] = "xxxxxxxxxx";
const String MyDayOfWeek[7] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
const String MyMonth[12] = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
int startTimeInSecs1;
int startTimeInSecs2;
int stopTimeInSecs2;
int startTimeInSecs3;
int stopTimeInSecs3;
int startTimeInSecs4;
int stopTimeInSecs4;
int NetworkDisconectedTimes = 0; // Reset every start-up
int NetConnectUp; // Reset every network re-conected
boolean AutoLamp1_Set = false;
boolean AutoLamp3_Set = false;
boolean AutoLamp5_Set = false;
boolean AutoLamp2_Set = false;
strDateTime dateTime;
DHT dht(DHTPIN, DHT11);
NTPtime MyNTP("id.pool.ntp.org");
WidgetLED VLED_SystemBlink(VLEDblink_Pin);
WidgetLED VLED_SensorDHT11(VLEDDHT11_Pin);
//WidgetLED VLED1(VLED1_Pin);
//WidgetLED VLED2(VLED2_Pin);
//WidgetLED VLED3(VLED3_Pin);
//WidgetLED VLED5(VLED5_Pin);
 *    This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
  Blynk.syncAll();
  Blynk.syncVirtual(VButton1_Pin);
  Blynk.syncVirtual(VButton3_Pin);
  Blynk.syncVirtual(VButton5_Pin);
  Blynk.syncVirtual(VButton2_Pin);
  Blynk.syncVirtual(VTimeInput1);
  Blynk.syncVirtual(VTimeInput2);
  Blynk.syncVirtual(VTimeInput3);
  Blynk.syncVirtual(VTimeInput4);
  NetworkDisconectedTimes++;
  Blynk.virtualWrite(VDisplayNetConnect_Pin, NetworkDisconectedTimes); // -- Disconected time counter on V21
  NetConnectUp = 0; // -- Reset Network Connection Uptime upon Network Disconected
  // -- Send email when reconnected not in startup
  if (NetworkDisconectedTimes > 1) {
    String MyDateTime = String(hour()) + MyPrintDigits(minute())+" - ";
    MyDateTime += MyDayOfWeek[weekday()-1]+", "+String(day())+"-"+MyMonth[month()-1]+"-"+String(year());
    Blynk.email("noersaleh@gmail.com", "Noer Home Automation just reconected: "+String(NetworkDisconectedTimes), "Reconected Time:"+MyDateTime);
 *  Define all button related to Lamp ON-OFF Toggle
BLYNK_WRITE(VButton1_Pin) //--  Lamp 1
  digitalWrite(D1, param.asInt());
//  if (digitalRead(D1)==1) {VLED1.on();} else {VLED1.off();}
  #ifdef DEBUG
  Serial.print("Virtual Button 1 ++> Pressed: ");
  Serial.print(param.asInt());
  Serial.print(" - ");
  Serial.println(digitalRead(D1));
  #endif
BLYNK_WRITE(VButton2_Pin) //-- Lamp 2
  digitalWrite(D2, param.asInt());
//  if (digitalRead(D2)==1) {VLED2.on();} else {VLED2.off();}
  #ifdef DEBUG
  Serial.print("Virtual Button 2 ++> Pressed: ");
  Serial.println(digitalRead(D2));
  #endif
BLYNK_WRITE(VButton3_Pin) //-- Lamp 3
  digitalWrite(D3, param.asInt());
//  if (digitalRead(D3)==1) {VLED3.on();} else {VLED3.off();}
  #ifdef DEBUG
  Serial.print("Virtual Button 3 ++> Pressed: ");
  Serial.println(digitalRead(D3));
  #endif
BLYNK_WRITE(VButton5_Pin) //-- Lamp 4
  digitalWrite(D5, param.asInt());
//  if (digitalRead(D5)==1) {VLED5.on();} else {VLED5.off();}
  #ifdef DEBUG
  Serial.print("Virtual Button 5 ++> Pressed: ");
  Serial.println(digitalRead(D5));
  #endif
 *  Define all button related to Auto / Manual Lamp ON-OFF
BLYNK_WRITE(VButtonTimer1_Pin) //-- Button Widget for Lamp 1 Auto (Timer Lamp)
  AutoLamp1_Set = (param.asInt()==1);
BLYNK_WRITE(VButtonTimer3_Pin) //-- Button Widget for Lamp 3 Auto (Timer or LDR)
  AutoLamp3_Set = (param.asInt()==1);
BLYNK_WRITE(VButtonTimer5_Pin) //-- Button Widget for Lamp 5 Auto (Timer or LDR)
  AutoLamp5_Set = (param.asInt()==1);
BLYNK_WRITE(VButtonTimer2_Pin) //-- Button Widget for Lamp 5 Auto (Timer or LDR)
  AutoLamp2_Set = (param.asInt()==1);
// --- This function will convert UTC (from TimeInput) to GMT+7
int UTCtoGMT7(int TimeInSecs)
  TimeInSecs += 25200; // --- From UTC convert to GMT+7
  if (TimeInSecs >= 86400) { // 86400 = 24hour x 3600
     TimeInSecs -= 86400;
  return TimeInSecs;
 *  Define Timer Time from Mobile Apps (Using TimeInput)
BLYNK_WRITE(VTimeInput1) {
  startTimeInSecs1 = UTCtoGMT7(param[0].asInt()); // UTC to GMT+7
  #ifdef DEBUG
  Serial.print("SET>> 1. Now  : ");
  Serial.print(hour()*3600+minute()*60);
  Serial.print(" --> Start: ");
  Serial.print(startTimeInSecs1);
  Serial.println(" - " + ClockFormat(startTimeInSecs1, false));
  #endif
BLYNK_WRITE(VTimeInput2) {
  startTimeInSecs2 = UTCtoGMT7(param[0].asInt()); // UTC to GMT+7
  stopTimeInSecs2 = UTCtoGMT7(param[1].asInt()); // UTC to GMT+7
  #ifdef DEBUG
  Serial.print("SET>> 2. Now  : ");
  Serial.print(startTimeInSecs2);
  Serial.print(" - " + ClockFormat(startTimeInSecs2, false));
  Serial.print(" - Stop : ");
  Serial.print(stopTimeInSecs2);
  Serial.println(" - " + ClockFormat(stopTimeInSecs2, false));
  #endif
BLYNK_WRITE(VTimeInput3) {
  startTimeInSecs3 = UTCtoGMT7(param[0].asInt()); // UTC to GMT+7
  stopTimeInSecs3 = UTCtoGMT7(param[1].asInt()); // UTC to GMT+7
  #ifdef DEBUG
  Serial.print("SET>> 3. Now  : ");
  Serial.print(startTimeInSecs3);
  Serial.print(ClockFormat(startTimeInSecs3, false));
  Serial.print(stopTimeInSecs3);
  Serial.println(ClockFormat(stopTimeInSecs3, false));
  #endif
BLYNK_WRITE(VTimeInput4) {
  startTimeInSecs4 = UTCtoGMT7(param[0].asInt()); // UTC to GMT+7
  stopTimeInSecs4 = UTCtoGMT7(param[1].asInt()); // UTC to GMT+7
  #ifdef DEBUG
  Serial.print("SET>> 4. Now  : ");
  Serial.print(startTimeInSecs4);
  Serial.print(" - " + ClockFormat(startTimeInSecs4, false));
  Serial.print(stopTimeInSecs4);
  Serial.println(" - " + ClockFormat(stopTimeInSecs4, false));
  #endif
// --- This function will sync current time with time from the "Network Time Protocol" Server
void SyncTimetoNTP()
  // first parameter: first parameter Time zone in floating point; second parameter: 0 no daylight saving, 1 for European summer time;
  dateTime = MyNTP.getNTPtime(7.0, 0);
  byte actualhour = dateTime.hour;
  byte actualminute = dateTime.minute;
  byte actualsecond = dateTime.second;
  int actualyear = dateTime.year;
  byte actualmonth = dateTime.month;
  byte actualday = dateTime.day;
  byte actualdayofWeek = dateTime.dayofWeek;
  setTime(dateTime.hour, dateTime.minute, dateTime.second, dateTime.day, dateTime.month, dateTime.year); //(hours, minutes, seconds, days, months, years)
  #ifdef DEBUG
  Serial.println("========================");
  Serial.println("= Sync to NTP Server:  =");
  MyNTP.printDateTime(dateTime);
  #endif
 *  Display Clock to Mobile Apps and Check & execute Timer setup
void DisplayClock_CheckAlarm()
  int MyNowSecond = hour()*3600+minute()*60+second();
  String MyTime = String(hour()) + MyPrintDigits(minute());
  String MyDate = MyDayOfWeek[weekday()-1]+", "+String(day())+"-"+MyMonth[month()-1]+"-"+String(year());
  Blynk.virtualWrite(VDisplayDate_Time, MyDate+" "+MyTime);
  // -- Check for ALAMRM
  if (AutoLamp2_Set) {
    if ((MyNowSecond >= startTimeInSecs1) && (MyNowSecond <= (startTimeInSecs1+20))) {
      Blynk.virtualWrite(VButton2_Pin, HIGH);
      digitalWrite(D2, HIGH);
      #ifdef DEBUG
      Serial.println();
      Serial.println("===========================");
      Serial.println("  ALARM -- ALARM -- ALARM");
      #endif
      Blynk.virtualWrite(VButton2_Pin, LOW);
      digitalWrite(D2, LOW);
    #ifdef DEBUG
    Serial.print("1. Now: ");
    Serial.print(now());
    Serial.print(" ("+String(MyNowSecond)+" vs. ");
    Serial.print(String(startTimeInSecs1));
    Serial.print(") --> Date: ");
    Serial.print(MyDate);
    Serial.print(" -- ");
    Serial.println(MyTime+MyPrintDigits(second()));
    #endif
  } // end if (AutoLamp_Set)
  // -- Check for Timer LAMP 1
  if (AutoLamp1_Set) {
    if ((MyNowSecond >= startTimeInSecs2) && (MyNowSecond <= (startTimeInSecs2+20))) {
      Blynk.virtualWrite(VButton1_Pin, HIGH);
      digitalWrite(D1, HIGH);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 1 ON");
      #endif
    if ((MyNowSecond >= stopTimeInSecs2) && (MyNowSecond <= (stopTimeInSecs2+20))) {
      Blynk.virtualWrite(VButton1_Pin, LOW);
      digitalWrite(D1, LOW);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 1 OFF");
      #endif
    #ifdef DEBUG
    Serial.print("2. Now: ");
    Serial.print(String(startTimeInSecs2));
    Serial.print("-");
    Serial.print(String(stopTimeInSecs2));
    #endif
  // -- Check for Timer LAMP 2
  if (AutoLamp3_Set) {
    if ((MyNowSecond >= startTimeInSecs3) && (MyNowSecond <= (startTimeInSecs3+20))) {
      Blynk.virtualWrite(VButton3_Pin, HIGH);
      digitalWrite(D3, HIGH);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 2 ON");
      #endif
    if ((MyNowSecond >= stopTimeInSecs3) && (MyNowSecond <= (stopTimeInSecs3+20))) {
      Blynk.virtualWrite(VButton3_Pin, LOW);
      digitalWrite(D3, LOW);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 2 OFF");
      #endif
    #ifdef DEBUG
    Serial.print("3. Now: ");
    Serial.print(String(startTimeInSecs3));
    Serial.print("-");
    Serial.print(String(stopTimeInSecs3));
    #endif
  // -- Check for Timer LAMP 3
  if (AutoLamp5_Set) {
    if ((MyNowSecond >= startTimeInSecs4) && (MyNowSecond <= (startTimeInSecs4+20))) {
      Blynk.virtualWrite(VButton5_Pin, HIGH);
      digitalWrite(D5, HIGH);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 3 ON");
      #endif
    if ((MyNowSecond >= stopTimeInSecs4) && (MyNowSecond <= (stopTimeInSecs4+20))) {
      Blynk.virtualWrite(VButton5_Pin, LOW);
      digitalWrite(D5, LOW);
      #ifdef DEBUG
      Serial.println();
      Serial.println("       LAMP 3 OFF");
      #endif
    #ifdef DEBUG
    Serial.print("4. Now: ");
    Serial.print(String(startTimeInSecs4));
    Serial.print("-");
    Serial.print(String(stopTimeInSecs4));
    #endif
} // End: DisplayClock_CheckAlarm()
 *  Display Network connection time
void sendNetConnectTime()
  // --  Blink LED that in Sync
  if (VLED_SystemBlink.getValue()) {
    VLED_SystemBlink.off();
    digitalWrite(SystemLED, LOW);
    VLED_SystemBlink.on();
    digitalWrite(SystemLED, HIGH);
  NetConnectUp++;
} // End: sendNetConnectTime()
 *  Display System Up time
void sendUptime()
  // ------------- Converting miliseconds to Clock and daisplay on Virtual Pin
  String MyClock = ClockFormat((millis() / 1000), false);
  Blynk.virtualWrite(VDisplayUptime_Pin, MyClock); //virtual pin 20 as UpTime
  Blynk.virtualWrite(VDisplayNetConnectUp_Pin, ClockFormat(NetConnectUp, false));
  #ifdef DEBUG
  Serial.print("Uptime (s): ");
  Serial.println(MyClock);
  #endif
} // End: sendUptime()
 *  Display DHT11 (temp and humidity) and LDR sensor
void sendDHT11_LDR()
  float h = dht.readHumidity();
  if (!isnan(t)) {Blynk.virtualWrite(VDisplayTemp_Pin, t); VLED_SensorDHT11.on();} // V10 -- LED off --> DHT Offline
  if (!isnan(h)) {Blynk.virtualWrite(VDisplayHumid_Pin, h);} else {VLED_SensorDHT11.off();} //V11
  int LDR_value = analogRead(LDRPIN);
  LDR_value = map(LDR_value, 0, 1023, 0, 100);  // -- convert value of 0-1023 to 0-100
  Blynk.virtualWrite(VDisplayLDR_Pin, LDR_value);
  #ifdef DEBUG
  Serial.print("D1 D3 D5 D2 Status:" );
  Serial.print(digitalRead(D1));
  Serial.print(" ");
  Serial.print(digitalRead(D3));
  Serial.print(" ");
  Serial.print(digitalRead(D5));
  Serial.print(" ");
  Serial.print(digitalRead(D2));
  Serial.print(" == Temp:" );
  Serial.print(t);
  Serial.print(" - Humidity:" );
  Serial.print(h);
  Serial.print(" - Light:" );
  Serial.println(LDR_value);
  #endif
} // End: sendDHT11_LDR()
// --- Utility function for digital clock display: prints preceding colon and leading 0
String MyPrintDigits(int digits)
  String new_digits = ":";
  if (digits < 10) {
    new_digits += "0";
  new_digits += String(digits);
  return new_digits;
// --- Utility function to convert seconds to clock format
String ClockFormat(int InputClock, boolean DisplaySecond)
  int my_h,my_m,my_s;
  my_h = InputClock / 3600; // Hour ==>> total_seconds div 3600
  String MyClock = String(my_h);
  my_m = InputClock%3600/60; // Minute ==>> total_seconds mod 3600 div 60
  MyClock += MyPrintDigits(my_m);
  if (DisplaySecond)
    my_s = InputClock%3600%60; // Second ==>> total_seconds mod 3600 mod 60
    MyClock += MyPrintDigits(my_s);
  return MyClock;
} // End: ClockFormat()
 * SETUP: Initialize for the first Time
  #ifdef DEBUG
  #endif
//  while (!Blynk.connect()) {
//    // Wait until connected
  pinMode(D1, OUTPUT);
  pinMode(D2, OUTPUT);
  pinMode(D3, OUTPUT);
  pinMode(D5, OUTPUT);
  pinMode(SystemLED, OUTPUT);
  dht.begin();
  SyncTimetoNTP();
  timer.setInterval(1000L, sendNetConnectTime); // every second
  timer.setInterval(5000L, sendDHT11_LDR);  // every 5 seconds
  timer.setInterval(60000L, sendUptime); // every minutes
  timer.setInterval(20000L, DisplayClock_CheckAlarm); // every 20 second
  timer.setInterval(3600000L, SyncTimetoNTP); // every hour sync with NTP Server
  Blynk.virtualWrite(VDisplayUptime_Pin, "0:00"); // Display initial UpTime
  Blynk.virtualWrite(VDisplayNetConnectUp_Pin, "0:00");  // Display initial last Network Connect time
  Blynk.email("noersaleh@gmail.com", "Noer Home Automation just restarted ... ", "RESTARTED ...");
} // End: setup()
 * LOOP: all the time
} // End: loop()
This is the shown on Serial:
 1384, room 16
tail 8
chksum �[21758] Connecting to Camar-24
[25761] Connected to WiFi
[25761] IP: 192.168.1.109
[25761] Blynk v0.3.8 on NodeMCU
11-9-2016 [1] - 19:58:51
[33718] Connecting to blynk-cloud.com:8442
D1 D3 D5 D2 Status:0 0 0 0 == Temp:nan - Humidity:nan - Light:1
[42126] Ready (ping: 271ms).
[47258] Login timeout
[47529] Connecting to blynk-cloud.com:8442
[55376] Ready (ping: 272ms).
[60616] Login timeout
[60887] Connecting to blynk-cloud.com:8442
As comparison I tried to upload following sketch, and is working perfectly…
char auth[] = "xxxxxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
The serial shown:
1384, room 16
tail 8
chksum �[20440] Connecting to Camar-24
[24443] Connected to WiFi
[24443] IP: 192.168.1.109
[24443] Blynk v0.3.8 on NodeMCU
[24443] Connecting to blynk-cloud.com:8442
[32362] Ready (ping: 1ms).
TIA
@noersaleh you really need to wait for the connection to be made so reinstate:
     //Wait until connected
Runs fine here on a WeMos D1 Mini without anything connected to the pins:
Connecting to MTN WIFI 19996
[6423] Connected to WiFi
[6423] IP: 192.168.10.207
[6423] Blynk v0.3.8 on Arduino
[6423] Connecting to blynk-cloud.com:8442
[6579] Ready (ping: 3ms).
Waiting for NTP packet
202.65.114.202
sending NTP packet...
NTP packet received, length=48
2016-9-11-1 21H 15M 19S
D1 D3 D5 D2 Status:0 0 0 0 == Temp:nan - Humidity:nan - Light:0
Thanks Costas for your suggestion,
but if I’m reinstate those line, I will no longer able to connect …
This is my serial shown:
 1384, room 16
tail 8
chksum �[21782] Connecting to Camar-24
[25785] Connected to WiFi
[25785] IP: 192.168.1.109
[25785] Blynk v0.3.8 on NodeMCU
[25785] Connecting to blynk-cloud.com:8442
[38711] Connecting to blynk-cloud.com:8442
[52211] Connecting to blynk-cloud.com:8442
[65416] Connecting to blynk-cloud.com:8442
[78629] Connecting to blynk-cloud.com:8442
[91349] Connecting to blynk-cloud.com:8442
[104589] Connecting to blynk-cloud.com:8442
and so on … never connected…
Currently I’m sting struggle to reconstruct my sketch with deleting line by line (suspicious command) that made Ping ms go high (275ms) …
best regards
What do you get if you ping blynk-cloud.com?
I get the IP as 46.101.143.225.
Maybe the cloud server for your area is “down”.
Try changing:
to:
Blynk.begin(auth, ssid, pass, "46.101.143.225");
You really MUST wait for a connection.
Unfortunately I got this message:
 1384, room 16
tail 8
chksum [21731] Connecting to Camar-24
[25734] Connected to WiFi
[25734] IP: 192.168.1.109
[25734] Blynk v0.3.8 on NodeMCU
[25734] Connecting to 46.101.143.225:8442
[26264] Invalid auth token
[31265] Connecting to 46.101.143.225:8442
[36805] Connecting to 46.101.143.225:8442
[37489] Invalid auth token
[42490] Connecting to 46.101.143.225:8442
[43121] Invalid auth token
[48122] Connecting to 46.101.143.225:8442
[48731] Invalid auth token
It seems the token is only valid only on my Blynk Server :wink:
Ah yes I think your token only works for your local cloud server.
What does the ping give you?
Last login: Sun Sep 11 18:41:02 on console
NSA-MacBookAir:~ noersaleh$ ping blynk-cloud.com
PING blynk-cloud.com (188.166.177.186): 56 data bytes
64 bytes from 188.166.177.186: icmp_seq=0 ttl=55 time=30.633 ms
64 bytes from 188.166.177.186: icmp_seq=1 ttl=55 time=59.267 ms
64 bytes from 188.166.177.186: icmp_seq=2 ttl=55 time=42.658 ms
64 bytes from 188.166.177.186: icmp_seq=3 ttl=55 time=135.026 ms
64 bytes from 188.166.177.186: icmp_seq=4 ttl=55 time=32.333 ms
64 bytes from 188.166.177.186: icmp_seq=5 ttl=55 time=58.966 ms
64 bytes from 188.166.177.186: icmp_seq=6 ttl=55 time=33.770 ms
64 bytes from 188.166.177.186: icmp_seq=7 ttl=55 time=42.497 ms
64 bytes from 188.166.177.186: icmp_seq=8 ttl=55 time=142.779 ms
64 bytes from 188.166.177.186: icmp_seq=9 ttl=55 time=52.456 ms
64 bytes from 188.166.177.186: icmp_seq=10 ttl=55 time=23.461 ms
64 bytes from 188.166.177.186: icmp_seq=11 ttl=55 time=26.458 ms
64 bytes from 188.166.177.186: icmp_seq=12 ttl=55 time=200.576 ms
No. It is not :slight_smile:.
On desperate attempt, I create new account on my Android and giving the Blynk address to 46.101.143.225 (upon login) as Costas sugested, create new project (clean slate) and get the auth code, write down the new auth code and new IP on Blynk.begin to my sketch.
Upload the sketch to my NodeMCU… at the beginning it looks promising … its working fine, unfortunately after several minutes back to the old problem…
[246] Connecting to Camar-24
[4249] Connected to WiFi
[4249] IP: 192.168.1.109
[4249] Blynk v0.3.8 on NodeMCU
[5001] Connecting to 46.101.143.225:8442
[5529] Ready (ping: 0ms).
[11552] Login timeout
[11552] Connecting to 46.101.143.225:8442
[12173] Ready (ping: 0ms).
[18407] Login timeout
[18407] Connecting to 46.101.143.225:8442
[19034] Ready (ping: 0ms).
[25269] Login timeout
[25270] Connecting to 46.101.143.225:8442
[25849] Ready (ping: 0ms).
[32129] Login timeout
[32129] Connecting to 46.101.143.225:8442
[32756] Ready (ping: 1ms).
[38895] Login timeout
So my Home Automation project is in halt state :slight_smile: so I think I have to call of the day, and try to sleep a while … lest try a new tricks tomorrow … :smile:
@noersaleh when you come back to it tomorrow do you have an ESP that isn’t wired up to anything?
Yes Costas, I already tried on Witity Cloud (NodeMCU) and NodeMCU with no other component attach, so far is having no luck yet… :slight_smile:
Thanks Costas … Finally I found the root cause of the problem, when I remove the Blynk.syncVirtual command, everything is working perfectly, so this line is actually giving me a big headache : :smile:
Strangely Blynk.syncAll() is working fine…
But now I found different issue:
  #ifdef DEBUG
  #endif
is not triggered when I change the value during runtime …
So my work arround is create a button to initiate a Blynk.syncVirtual() … and luckily is not giving me a time out issue … :slight_smile: :slight_smile: :slight_smile:
best regards
@noersaleh see my post on your other thread about sync Hardware init connecting to blynk server takes long time
Have you done a pin definition in your code to use “VTimeInput1” as a reference?
Yes Costas,
