I was able to build library for my host linux (Ubuntu) and for Raspberry Pi.
Cross-compilation is currently not supported, but you could easily modify the Makefile in the linux directory to build it for OpenWRT.
After compiling you will be able to use virtual pins. For Analog/Digital operations, more modifications in the library are needed (it’s a rather easy step, just implementing the proper handlers for your platform).
I am also willing to help.
To begin with recommended to connect the Arduino for USB (blynk-library-master \ examples \ BoardsAndShields \ Arduino_Serial_USB \ Arduino_Serial_USB.ino) to execute a script on the router (blynk-library-master \ scripts \ blynk-ser.sh).
The next step is to use the built-in serial- port (UART- console) , and then integrated GPIO.
Thank you!
is that will make the local server fully running on the Openwrt Router , or just as client which will need to
have a server and Auth token to communicate with?
Pi has an issue with SD card getting corrupted after some time , if no option to use Openwrt router.
i will install it on my Old case which is running as NAS
No, not really, but I see companies like HPE use them for their vmware servers. I have a couple of those. The ones I have are really rotten expensive, like 50 euro’s each, but that’s retail price.
