(Solved) Help with coding notification delays
All 3 and in definitions. See PUSH_DATA example for the elements of SimpleTimer.
Many users put the setInterval in setup() but it can go anywhere except loop() that should be kept to a maximum of 2 lines of code.
Depends on the type of timer, what you want it to do and whether it is a continuously running or temporarily running timer… checkout #12 here for some timer examples
Ok I have the sketch working with timers but my next question is will a delay within a function halt the sketch? I have a LCDdisplay function displaying Name then switching to Greenhouse Temp and then Time with a delay of 3 seconds between screens. If delay does halt sketch what is the best way to get around this? I went with the BlynkTimer
   void LCDdisplay()
// set up the LCD's number of columns and rows:
  // Print a message to the LCD.
    lcd.clear ();
    lcd.setCursor(0, 0);
    lcd.print ("Windy Ridge Farm");
    delay(3000);
  lcd.clear ();
  lcd.print("Greenhouse Temp:" );
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  lcd.print(GreenhouseTemp);
  lcd.print((char)223);
  lcd.print ("F");
  delay (3000);
DateTime now = rtc.now();
   char dateBuffer[12];
      //Print Second Line
    lcd.clear ();
    lcd.print ("Eastern Time:");
    sprintf(dateBuffer,"%02u:%02u ",now.hour(),now.minute());
    lcd.print(dateBuffer);
   delay (3000);
Yes, it halts everything
Fancy use of timers… look at the link I sent already in previous post (links are in green… at least on a PC)
Gunner Thanks for all your help!! I think I finally got it figured out I will post the updated code with no delay to get your thoughts on anything else i could do to make it better. The sketch compiles and everything is working as intended
    Sketch generator:           http://examples.blynk.cc
    Blynk community:            http://community.blynk.cc
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - Arduino Ethernet board
   - Decide how to connect to Blynk
     (USB, Ethernet, Wi-Fi, Bluetooth, ...)
  There is a bunch of great example sketches included to show you how to get
  started. Think of them as LEGO bricks  and combine them as you wish.
  For example, take the Ethernet Shield sketch and combine it with the
  Servo example, or choose a USB sketch and add a code from SendData
  example.
#include <Ethernet.h>
#include <OneWire.h>
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
#define ONE_WIRE_BUS 7          //Arduino Mega Digital Pin 7
RTC_DS3231 rtc;
char auth[] = "***********************";
#define W5100_CS  10
#define SDCARD_CS 4
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
#define Relay_1  40  // Arduino Digital I/O pin number
#define Relay_2  41
#define Relay_3  42
#define Relay_4  43
int displayState = 0;
int GreenhouseTemp;            // Greenhouse temperature in F
unsigned long previousMillis1 = 0;        // will store last time Display was updated
long interval = 3000; // m
//int timeState = LOW;
unsigned long previousMillis2 = 0;       // will store last time Time was updated
long OnTime = 100;           // milliseconds of on-time
long OffTime = 200;          // milliseconds of off-time
int sensorPin = 0;    // select the input pin for the potentiometer
int sensorValue = 0;  // variable to store the value coming from the sensor
  pinMode(SDCARD_CS, OUTPUT);
  //Blynk.begin(auth);
  Blynk.begin(auth, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, IPAddress(192,168,10,222), 8442);
  // Send e-mail when your hardware gets connected to Blynk Server
  // Just put the recepient's "e-mail address", "Subject" and the "message body"
  Blynk.email("***********************", "Subject", "Greenhouse is online.");
     lcd.init();      // initialize the lcd
     lcd.backlight(); // Turn on LCD Backlight
   // Uncomment to set time to PC time
  //rtc.begin();
  //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {
    //Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust (DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // Adjust Time on line Below
    //rtc.adjust(DateTime(2017, 8, 23, 10, 36, 0));
      //---( THEN set pins as outputs )----
  pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  //delay(1000); //Check that all relays are inactive at Reset
    //-------( Initialize Pins so relays are inactive at reset)----
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
 timer.setInterval(1000L, Date_Time );
 timer.setInterval(1000L, sendTemps );
 timer.setInterval(3000L, LCDdisplay );
 timer.setInterval(1000L, Temp );
 timer.setInterval(1000L, sendTime );
  // to avoid delay() function!
   void sendTemps()
  sensors.requestTemperatures();                  // Polls the sensors.
  GreenhouseTemp = sensors.getTempFByIndex(0);   // Stores temperature. Change to getTempCByIndex(0) for celcius.
  Blynk.virtualWrite(V5, GreenhouseTemp);         // Send temperature to Blynk app virtual pin 1.
   void sendTime()
   Serial.println(dateBuffer);
   Blynk.virtualWrite(V1,dateBuffer);
   void LCDdisplay()
 // check to see if it's time to change the state of the LED
  unsigned long currentMillis = millis();
  if((displayState  == 0) && (currentMillis - previousMillis1 >= interval))
    displayState = 1;  // Turn it off
    lcd.clear ();
     else if ((displayState == 1) && (currentMillis - previousMillis1 >= interval))
    displayState = 2;  // turn it on
    previousMillis1 = currentMillis;   // Remember the time
    lcd.clear ();
    lcd.print ("F");
  else if((displayState  == 2) && (currentMillis - previousMillis1 >= interval))
    displayState = 0;  // Turn it off
      //Print Second Line
    lcd.clear ();
   void Date_Time ()
   sprintf(dateBuffer,"%02u-%02u-%04u ",now.month(),now.day(),now.year());
   Serial.print(dateBuffer);
   sprintf(dateBuffer,"%02u:%02u:%02u ",now.hour(),now.minute(),now.second());
      // ********Watering Schedule***********
  int SchOn1 = (now.hour() == 8 & now.minute() == 30 & now.second() <= 10);
  int SchOff1= (now.hour() == 8 & now.minute() == 33 & now.second() <= 10);
  int SchOn2 = (now.hour() == 17 & now.minute() == 30 & now.second() <= 10);
  int SchOff2= (now.hour() == 17 & now.minute() == 33 & now.second() <= 10);
    if((SchOn1) && (currentMillis - previousMillis2 >= OnTime))
    Blynk.notify("Plants Just Watered!");
    Blynk.email("***********************", "Subject: Greenhouse", "Plants Just Watered!");
    digitalWrite(Relay_2, RELAY_ON);// Turn the Watering Relay ON
    else if ((SchOff1) && (currentMillis - previousMillis2 >= OffTime))
    previousMillis2 = currentMillis;   // Remember the time
    digitalWrite(Relay_2, RELAY_OFF);// Turn the Watering Relay OFF
    if((SchOn2) && (currentMillis - previousMillis2 >= OnTime))
   else if ((SchOff2) && (currentMillis - previousMillis1 >= OffTime))
void Temp()
     //***********Cooling Code***************
  if (GreenhouseTemp >= 85)
     { digitalWrite (Relay_1, RELAY_ON);}//Greenhouse Temp Control Fan ON Above 85 Degrees
  else if  ((GreenhouseTemp > 73)  && (GreenhouseTemp< 75))
     { digitalWrite (Relay_1, RELAY_OFF);}  //Greenhouse Temp Control  coolingFan OFF Below 75 Degrees
    bool tempflag = true;
   if ((GreenhouseTemp >= 95)  && (tempflag == true))
   Blynk.notify("GREENHOUSE OVERHEATING!!!");
   tempflag = false;
if (GreenhouseTemp < 95)
  tempflag = true;
    //*************Heating Code****************
  if  ((GreenhouseTemp > 55)  && (GreenhouseTemp< 57))
  { digitalWrite (Relay_3, RELAY_OFF);}    //Greenhouse Temp Control Heater Fan OFF Above 55 Degrees F
  if (GreenhouseTemp  <= 45.00)
  { digitalWrite (Relay_3, RELAY_ON);}  //Greenhouse Temp Control Heater Fan ON Below 45 Degrees F
yes bl**dy backticks.
is that better?
Nope
3 backticks
sketch
3 backticks
i don’t understand what your talking about what is a backtick
If you don’t understand what anyone tells you ask big G.
https://www.google.com/search?q=what+is+a+backtick
Some forum mods kindly add the backticks for you, but I prefer to teach people how to fish rather than simply handing out the fish.
well Im out of worms, where in the sketch are they needed and why what is their purpose im new at coding? Big G told me where they are on the keyboard but not what they are used for in a sketch
It’s not related to coding. It relates to posting certain things on forums that people can easily read.
Now you know what a backtick is, does my earlier post make any sense?
I prefer to labour the point so you and others become great anglers.
yes now is that better?
Just beautiful, now remove the second entry of Serial.begin(9600); in setup().
Coders don’t really want to look through your original posting of the sketch. Sure you would agree it’s much easier to understand now and specifically coders can easily grab a copy and put it in their IDE for debugging.
Without backticks copy and paste from this and other forum sites is not possible without us going through each line and formatting the sketch.
Ok thanks
I like to do both, fix the issue then show how… and badger repeatedly if not listened to :stuck_out_tongue:
I learn by example, so I try to teach the same way.
Takes more effort on my part, but it seems effective… eventually
@bcomer Backticks :wink:
Blynk - FTFC
@Gunner when I have time I like to provide the details of why we are using a barbed hook to trap the fish, like in this thread. I made a promise to myself that I wasn’t going to waste any more of my time adding backticks for Blynkers and I’m sticking with it.
Time I have… energy and focus, well… when I do, I don’t mind helping by doing (and badger…er… explaining :wink: )
I think we tag team well between our methods :smiley:
Here is what i came up with to solve the notification problem. Seems to work
   tempflag = false;
  tempflag = true;
