i have Raspberry Pi Zero with NOOBS operating system i just downloaded the new Blynk server.jar
then ran the new server
then changed the crontab to the new server
then rebooted
and it went to emergency mode
in the start up it showed a few fails, including something about āfailed to mount /bootā and system-random-seed.service failure
how can i recover my Blynk server?!
i dont have another linux machine availableā¦
i used DiskInternals Linux Reader and got my Blynk folder out of the SD card and then created a new Raspberry Pi server, then copied the Blynk folder & Blynk server.jar across and it worked first goā¦
@Dave1829
I renamed the .jar file in my installation folder to āserver.jarā.
So for updating the server I just have to replace the old file with the new one and reboot.
To keep in mind which version Iām on I keep the file with the original name one folder above.
Maybe this could make things easier for you
Thanks!
It was already pretty easy but this will definitely reduce the risk of clumsy fingers mistakes!
Instead of that, make a symlink to it, that way you still can see the original file version
Update script, save it in the blynk folder and call it update.sh, chmod +x update.sh to make it executable. It works on my Pi. Change the BASE variable to your Blynk folder (where the server-x.xx.x.jar file is).
#!/bin/bash
# Update script for Blynk Server on Linux-like systems.
# This script relies on the use of curl for fetching Blynk.jar file
# It also has a reference to "blynk.sh", which is my start script.
# My blynk.sh script refers to "server.jar" which is a symbolic link
# to the actual server.jar file. That way it's easy to use in startup
# routines etc.
# You can change the variables to your local situation (mine is a Raspberry
# Pi with OpenELEC, hence the Storage path).
# This is a really dirty script, it doesn't do RegEx, but just assumes
# that the URL for GitHub will always be the same length (which it
# probably will).
# BEGIN User variables, change these to your situation
# Base path to your Blynk server.jar file
BASE=/storage/blynk
# Startup script name (full path)
STARTUP="$BASE/blynk.sh"
# The symlink used in blynk.sh startup file (full path)
SYMLINK="$BASE/server.jar"
# END USER VARIABLES, change below only if you are sure
# about it ;-)
URL=https://github.com/blynkkk/blynk-server/releases/latest
REDIRECT=`curl $URL`
LATESTVERSION=${REDIRECT:89:6}
DOWNLOAD="http://github.com/blynkkk/blynk-server/releases/download/v$LATESTVERSION/server-$LATESTVERSION.jar"
CURRENT=`readlink $SYMLINK`
CURRENTVERSION=${CURRENT:7:6}
echo "### Current version from Symlink ###"
echo $CURRENTVERSION
echo "### New Version ###"
echo $LATESTVERSION
if [ $CURRENTVERSION = $LATESTVERSION ] ; then
echo "You are up to date"
exit 0
echo "New version available, downloading"
wget $DOWNLOAD
fi
echo "Removing old Symlink and making new one"
rm $SYMLINK
ln -s server-$LATESTVERSION.jar server.jar
# Call the other startup script here
echo "Restarting Blynk server"
/bin/bash $BASE/blynk.sh restart
echo "All done!"
