You’ll need:
- Blynk App (download from AppStore or Google Play)
- ESP32 board
example.
// #define BLYNK_HEARTBEAT 2
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "eJ1MtrcUnLlws_9kk4fOjcXYUuHnkJZQ";
char ssid[] = "SKY351AE2.4";
char pass[] = "********";
// Blynk.begin(auth, ssid, pass, "139.59.206.133", 8080);
// Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Good afternoon all,
I’ve been struggling for days trying to overcome a “Heartbeat timeout” error. The project runs and will function for around 17 mins before generating the error. This is consistent and repeatable.
I have a good internet connection and a ping of 45ms.
I’ve tried changing the port to 8080 with the same results.
I’ve also tried experimenting with #define BLYNK_HEARTBEAT. I’m not sure if the syntax is correct but in any case, it has no effect.
I’ve tried different ESP32’s just in case but the results were the same.
I’ve also tried connecting via a mobile hotspot on my phone AND THAT WORKS! Even with a poor signal and a ping of 250ms. No problems!
I’m assuming that as it will initially connect and function that there’s no port blocking going on and my router settings are OK. I have have tried setting up a port forward but again it made no difference.
After the error is generated the router shows that the ESP32 is still connected.
After the error it tries to reconnect but always fails. A hardware reset will force it to reconnect.
Any help would be greatly appreciated. My last foray into the world of coding was with Basic in the mid 80’s on a Tutung Einstein so the “Noddy” guide would be prefered :-).
Thanks and regards.
