I use both 1.6.4 and 1.0.5 IDE’s… Lots of errors with bad naming in sketch names in 1.0.5. 1.0.5 does not like “boards-json” folder either. It also does not like Sketches with “-”. Not a big deal, but more of a pain…
Thanks for the report. I also used 1.0.6 before, didn’t have any troubles. Could you specify exactly examples with naming troubles? As for the boards-json I will rename it soon.
Sorry, I don’t see the example you’re talking about.
We have ESP8266_Shield and ESP8266_Standalone examples and neither has “-” in the name.
The boards-json is renamed in the master branch as you suggested.
Test on Particle Core with example and it works very well. I can’t seem to tweet out and I don’t see the push notification from the example. I am using an iPad with the latest iOS version.
