Oh lawd
cant compile it right now, im on my phone… Im using a particle photon and particle IDE on build.particle.io
@Jamin yeah i ordered some of those little bugs you were talking about, still waiting…
Edit: the example on particle ide is this, i think its similar to simpletimer…
// Spark Interval Timer demo
// Please refer to the github README file for more details:
// https://github.com/pkourany/SparkIntervalTimer/blob/master/README.md
// This demo will create several Interval Timers (3 on Core, 5 on Photon) to blink
// LEDs at different intervals. The first timer will blink the onboard LED
// while extra LEDs (and small current limiting resistors) must be added
// by the user on pins D3 and D4 (Core) and additionally on D5 and D6 for Photon.
// After 100 blinks, Timer1 will reset to 1/4 of its interval and after 200 more
// blinks, Timer1 is shut down and will stop blinking.
#include "SparkIntervalTimer/SparkIntervalTimer.h"
SYSTEM_MODE(MANUAL); //For this demo, WiFi and Cloud connections are disabled
// Create IntervalTimer objects
IntervalTimer myTimer; // 3 for the Core
IntervalTimer myTimer2;
IntervalTimer myTimer3;
#if (PLATFORM_ID == 6) // 2 more for the Photon
IntervalTimer myTimer4;
IntervalTimer myTimer5;
#endif
// Pre-declare ISR callback functions
void blinkLED(void);
void blinkLED2(void);
void blinkLED3(void);
#if (PLATFORM_ID == 6) // Extras for Photon
void blinkLED4(void);
void blinkLED5(void);
#endif
const uint8_t ledPin = D7; // LED for first Interval Timer
const uint8_t ledPin2 = D3; // LED for second Interval Timer
const uint8_t ledPin3 = D4; // LED for third Interval Timer
const uint8_t ledPin4 = D5;
const uint8_t ledPin5 = D6;
#endif
void setup(void) {
pinMode(ledPin, OUTPUT); // Configure LED pins as OUTPUTs
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
#if (PLATFORM_ID == 6) //Extras for Photon
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
#endif
// AUTO allocate blinkLED to run every 500ms using hmSec timescale (1000 * 0.5ms period)
// On Core the first allocated timer is TIMER2. On Photon, it is TIMER3.
myTimer.begin(blinkLED, 1000, hmSec);
// Manually allocate blinkLED2 to hardware timer TIMER4 to run every 250ms using hmSec timescale (500 * 0.5ms period)
// TIMER4 is common to both Core and Photon.
myTimer2.begin(blinkLED2, 500, hmSec, TIMER4);
// Auto allocate blinkLED3 to run every 1000ms using hmSec timescale (2000 * 0.5ms period)
// On Core allocated timer will be first free = TIMER3. On Photon, it will be TIMER5.
myTimer3.begin(blinkLED3, 2000, hmSec);
// Auto allocate blinkLED4 to run every 65ms using uSec timescale (65000 * 1us period)
// On Photon (only) allocated timer will be next free = TIMER6.
myTimer4.begin(blinkLED4, 65000, uSec);
// Manually allocate blinkLED5 to hardware timer TIMER7 blinkLED to run every 5000ms (10000 * .5ms period)
myTimer5.begin(blinkLED5, 10000, hmSec, TIMER7);
#endif
// The first TIMER (myTimer) interrupt will blink the LED, and keep
// track of how many times it has blinked. After 200 on/off cycles
// the timer interval will be changed to 125ms (250 * 0.5ms).
// After a further 200 pulses, the timer will be shut down.
// All other timers only blink their associated LEDs
volatile unsigned long blinkCount = 0; // use volatile for variables shared with ISR
// functions called by IntervalTimer should be short, run as quickly as
// possible, and should avoid calling other functions if possible.
// Callback for Timer 1
void blinkLED(void) {
digitalWrite(ledPin,!digitalRead(ledPin));
blinkCount++; // increase when LED turns changes
// Callback for Timer 2
void blinkLED2(void) {
digitalWrite(ledPin2,!digitalRead(ledPin2));
// Callback for Timer 3
void blinkLED3(void) {
digitalWrite(ledPin3,!digitalRead(ledPin3));
#if (PLATFORM_ID == 6) // Extras for the Photon
// Callback for Timer 4
void blinkLED4(void) {
digitalWrite(ledPin4,!digitalRead(ledPin4));
// Callback for Timer 5
void blinkLED5(void) {
digitalWrite(ledPin5,!digitalRead(ledPin5));
#endif
void loop(void) {
if (blinkCount == 200) { // After 200 on/off cycles, change first timer interval
// to 125ms (250 * 0.5ms) for next 200 cycles.
blinkCount++; // increment count so IF does not trigger again
myTimer.resetPeriod_SIT(250, hmSec);
else if (blinkCount >= 400) { // After 200 more on/off cycles, shut down first timer
blinkCount = 0; // reset count so IF does not keep passing
myTimer.end(); // Disable the first timer
but i think something might be wrong with the code since im not getting any readings nor being able to activate the relays using Vpins, only if i set the buttons to the corresponding digital pins…
). Now it should return a value. If it doesn’t, try another Pin.
