Blynk has an RTC widget so you don’t need a hardware part anymore to get the time from the Interwebz. It’s really nice to use and saves a couple bucks on hardware, but I’m not sure if you use a hardware RTC, so I thought I’d mention it
Yeah blynk’s rtc ftw ahah next its try and figure out how to make a weak and day conter. im taking a few days off for vacations and i’ll be back with the full code and pics (i hope). Thanks guys
Im having problems getting through these errors, i’ve making changes after setting the dashboard on my phone, if i anyone could help me it would be great…
/* MeLion GrowBox 0.1 */
#include "PietteTech_DHT/PietteTech_DHT.h"
#include "blynk/blynk.h"
// system defines
#define DHTTYPE DHT11 // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPIN 0 // Digital pin for communications
#define DHT_SAMPLE_INTERVAL 600 // Sample every minute
//declaration
void dht_wrapper(); // must be declared before the lib initialization
// Lib instantiate
PietteTech_DHT DHT(DHTPIN, DHTTYPE, dht_wrapper);
// globals
unsigned int DHTnextSampleTime; // Next time we want to start sample
bool bDHTstarted; // flag to indicate we started acquisition
int n; // counter
char auth[] = ""; //Set token from the Blynk app
char VERSION[64] = "0.04";
#define READ_INTERVAL 60000
// My garden setup
bool shutdownButton = 1;
// Moisture variables
int humid1;
int moistureBreakpoint = 60;
bool extractionInProgress = false;
int moistureValueVirtual;
bool extractionButton = 0;
// Temperature variables
int temp1;
int temperatureBreakpointLow = 20;
int temperatureBreakpointHigh = 23;
bool heatingInProgress = false;
bool heatingButton = 0;
// Lighting variables
bool lightingButton = 0;
// Timer variables
unsigned long Timer;
unsigned long milis;
delay(5000);
Blynk.begin(auth);
DHTnextSampleTime = 0; // Start the first sample immediately
// This wrapper is in charge of calling
// must be defined like this for the lib work
void dht_wrapper() {
DHT.isrCallback();
// Outputs
pinMode(D1, OUTPUT); //Output for LED Lighting relay
pinMode(D2, OUTPUT); //Output for Extraction fan relay
pinMode(D3, OUTPUT); //Output for Heater relay
// Initial timer setup
Timer = millis();
Serial.println("done setup");
// Check if we need to start the next sample
if (millis() > DHTnextSampleTime) {
if (!bDHTstarted) { // start the sample
DHT.acquire();
bDHTstarted = true;
if (!DHT.acquiring()) { // has sample completed?
float temp = (float)DHT.getCelsius();
int temp1 = (temp - (int)temp) * 100;
char tempInChar[32];
sprintf(tempInChar,"%0d.%d", (int)temp, temp1);
float humid = (float)DHT.getHumidity();
int humid1 = (humid - (int)humid) * 100;
char humidInChar[32];
sprintf(humidInChar,"%0d.%d", (int)humid, humid1);
// Converting moisture to virtual and sending to Blynk
moistureVirtual();
n++; // increment counter
bDHTstarted = false; // reset the sample flag so we can take another
DHTnextSampleTime = millis() + DHT_SAMPLE_INTERVAL; // set the time for next sample
// Main function that times and calls all of the other subfunctions
growBoxMaster();
void growBoxMaster()
milis = millis();
if(milis - Timer >= 1000UL)
Serial.println("********************* Timed pseudoloop execution *********************");
shutdownMaster();
moistureMaster();
heatingMaster();
lightingMaster();
Timer = millis();
void shutdownMaster()
Serial.println("------- shutdownMaster started -------");
if(!shutdownButton)
startShutdown();
// Printing important values
Serial.print("shutdownButton - ");
Serial.println(shutdownButton);
void startShutdown()
digitalWrite(1, LOW);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
Blynk.virtualWrite(28, 1023);
Serial.println("SHUTDOWN");
void moistureMaster()
Serial.println("------- moistureMaster started -------");
if((humid1 > moistureBreakpoint) && (!extractionInProgress) && (extractionButton = HIGH))
extractionInProgress = true;
startExtraction();
if ((humid1 > moistureBreakpoint) && (!extractionInProgress) && (extractionButton = LOW))
startExtraction();
if((humid1 < moistureBreakpoint) && (extractionInProgress) && (extractionButton = HIGH))
startExtraction();
if ((humid1 < moistureBreakpoint) && (extractionInProgress) && (extractionButton = LOW))
stopExtraction();
Serial.print("humid1 - ");
Serial.println(humid1);
Serial.print("extractionInProgress - ");
Serial.println(extractionInProgress);
Serial.print("moistureBreakpoint - ");
Serial.println(moistureBreakpoint);
void startExtraction()
digitalWrite(2, HIGH);
Blynk.virtualWrite(25, 1023);
Serial.println("Extraction - started");
void stopExtraction()
Blynk.virtualWrite(25, 0);
Serial.println("Extraction - stoped");
void heatingMaster()
Serial.println("------- heatingMaster started -------");
getTemperature();
if((temp1 < temperatureBreakpointLow) && (!heatingInProgress) && (!heatingButton))
heatingInProgress = true;
startHeating();
else if((temp1 < temperatureBreakpointLow) && (!heatingInProgress) && (heatingButton))
stopHeating();
else if((temp1 >= temperatureBreakpointHigh) && (heatingInProgress) && (!heatingButton))
stopHeating();
else if((temp1 >= temperatureBreakpointHigh) && (heatingInProgress) && (heatingButton))
startHeating();
Serial.print("temp1 - ");
Serial.println(temp1);
Serial.print("heatingInProgress - ");
Serial.println(heatingInProgress);
Serial.print("temperatureBreakpointLow - ");
Serial.println(temperatureBreakpointLow);
Serial.print("temperatureBreakpointHigh - ");
Serial.println(temperatureBreakpointHigh);
Serial.print("heatingButton - ");
Serial.println(heatingButton);
void startHeating()
digitalWrite(3, HIGH);
Blynk.virtualWrite(24, 1023);
Blynk.virtualWrite(21, HIGH);
Serial.println("Heating - started");
void stopHeating()
Blynk.virtualWrite(24, 0);
Blynk.virtualWrite(21, LOW);
Serial.println("Heating - stoped");
void getTemperature()
Blynk.virtualWrite(26, temp1);
void LightingMaster()
if(!lightingButton)
startLighting();
else if(lightingButton)
stopLighting();
Serial.print("lightingButton - ");
Serial.println(lightingButton);
void startLighting()
digitalWrite(1, HIGH);
Blynk.virtualWrite(22, 1023);
Serial.println("Lighting - started");
void stopLighting();
Blynk.virtualWrite(22, 0);
Serial.println("Lighting - stopped");
// Getting value of moistureBreakpoint
BLYNK_WRITE(V2)
int pinData = param.asInt();
moistureBreakpoint = pinData;
// Getting value of temperatureBreakpointLow
BLYNK_WRITE(V4)
temperatureBreakpointLow = pinData;
// Getting value of temperatureBreakpointHigh
BLYNK_WRITE(V5)
temperatureBreakpointHigh = pinData;
// Getting value of shutdownButton
BLYNK_WRITE(V6)
bool pinData = param.asInt();
shutdownButton = pinData;
// Getting value of extractionButton
BLYNK_WRITE(V6)
extractionButton = pinData;
// Getting value of LightingButton
BLYNK_WRITE(V7)
lightingButton = pinData;
// Getting value of heatingbutton
BLYNK_WRITE(V8)
heatingButton = pinData;
void moistureVirtual()
Blynk.virtualWrite(20, humid1);
errors:
from blynk/BlynkSimpleParticle.h:14,
from blynk/blynk.h:2,
from blynkt.cpp:4:
blynk/BlynkApiParticle.h:90:6: warning: #warning "analogInputToDigitalPin not defined => Named analog pins will not work" [-Wcpp]
blynkt.cpp:16:1: error: expected unqualified-id before 'else'
else if(lightingButton);
blynkt.cpp: In function 'void growBoxMaster()':
blynkt.cpp:131:20: error: 'lightingMaster' was not declared in this scope
blynkt.cpp: In function 'void LightingMaster()':
blynkt.cpp:290:18: error: 'stopLighting' was not declared in this scope
blynkt.cpp: At global scope:
blynkt.cpp:305:1: error: expected unqualified-id before '{' token
startLighting();
In file included from blynk/BlynkApi.h:17:0,
from blynk/BlynkApiParticle.h:14,
from blynk/BlynkParticle.h:14,
from blynkt.cpp:4:
blynkt.cpp: In function 'void BlynkWidgetWrite6(BlynkReq&, const BlynkParam&)':
This looks like an error in blynk library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
blynk/BlynkHandlers.h:155:10: error: redefinition of 'void BlynkWidgetWrite6(BlynkReq&, const BlynkParam&)'
void BlynkWidgetWrite ## pin (BlynkReq& request, const BlynkParam& param)
blynk/BlynkHandlers.h:163:31: note: in expansion of macro 'BLYNK_WRITE_2'
#define BLYNK_WRITE(pin) BLYNK_WRITE_2(pin)
blynkt.cpp:345:1: note: in expansion of macro 'BLYNK_WRITE'
CREATE ISSUE
blynk/BlynkHandlers.h:155:10: error: 'void BlynkWidgetWrite6(BlynkReq&, const BlynkParam&)' previously defined here
blynkt.cpp:337:1: note: in expansion of macro 'BLYNK_WRITE'
make[1]: *** [../build/target/user/platform-6blynkt.o] Error 1
make: *** [user] Error 2
Error: Could not compile. Please review your code.
Wow sorry but your code is messy
What board are you using? I will try to compile it here with changes.
A few things I can see though:
- Put everything in dht_wrapper() (pinMode(), timer and serial output) in setup() and ditch the function all together.
- Put vars with values in setup(), not just with the #defines.
- In loop() put if(Blynk.connected()){blynk.run(); );
- Take all the DHT stuff out of loop and put it in a function with a 2sec timer so you’re not calling it thousands of times a sec when the DHT only transmits every 2 seconds anyway.
- Define your pins above setup(). I see that in your startShutdown() function you have digitalWrite’s with direct pin numbers. Replace these with definitions.This is more in line of best practice for coding. Also helps if you need to change the pins for whatever reason later. Change it in one place.
Many of your declaring errors will go away if you put the loop() as the very last thing in the sketch.
I find that the best order of a sketch is:
defines
global vars declarations
setup()
blynk_writes()
void functions for your project
loop()
So try reorganizing the layout of your sketch to be more in line with this concept.
Hope this helps!
The LightingMaster is easy, you spelled it with a capital L naming the function, but you are calling it with a lowercase L.
But I do agree with @Jamin. If you clean it up a bit and adhere to what is become to known as the golden Blynk standard it’ll look much nice and will be easier to maintain and more fun to deal with!
Great help and tips! Yeah im a messy noob ahah going to clean up a bit using what you said to make it more clear to spot errors.
Cheers guys!
Edit: im using a particle photon @Jamin
i tried to organize things and to structure the code according to the order advised but i still have lots of errors and now my head hurts from trying to understand this new way ahah so far i have this…
#include "Adafruit_DHT/Adafruit_DHT.h"
// system defines
// Sensor Declaration
#define DHTPIN 4
#define ledRelay 1 // D1 pin output to Lighting LED's relay
#define fanRelay 2 // D2 pin output to Extraction Fan relay
#define heatRelay 3 // D3 pin output to Heating relay
#define dhtIn 4 // D4 pin input from DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "";
// Garden setup
int humid1;
int temp1;
// Timer variables
// Outputs
pinMode(ledRelay, OUTPUT); //Output for LED Lighting relay
pinMode(fanRelay, OUTPUT); //Output for Extraction fan relay
pinMode(heatRelay, OUTPUT); //Output for Heater relay
pinMode(dhtIn, INPUT); //Input for the DHT pin
Blynk.begin(auth);
dht.begin();
BLYNK_WRITE(V2)
BLYNK_WRITE(V4)
BLYNK_WRITE(V5)
BLYNK_WRITE(V6)
BLYNK_WRITE(V6)
BLYNK_WRITE(V7)
BLYNK_WRITE(V8)
milis = millis();
dhtReadings();
shutdownMaster();
moistureMaster();
heatingMaster();
lightingMaster();
Timer = millis();
// Get Readings
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a
// very slow sensor)
void dhtReadings();
float humid1 = dht.getHumidity();
// Read temperature as Celsius
float temp1 = dht.getTempCelcius();
// Read temperature as Farenheit
float f = dht.getTempFarenheit();
// Check if any reads failed and exit early (to try again).
if (isnan(humid1) || isnan(temp1) || isnan(f)) {
return;
// Compute heat index
// Must send in temp in Fahrenheit!
float hi = dht.getHeatIndex();
float dp = dht.getDewPoint();
float k = dht.getTempKelvin();
Serial.print("Humid: ");
Serial.print(humid1);
Serial.print("% - ");
Serial.print("Temp: ");
Serial.print(temp1);
Serial.print("*C ");
Serial.print(f);
Serial.print("*F ");
Serial.print(k);
Serial.print("*K - ");
Serial.print("DewP: ");
Serial.print(dp);
Serial.print("*C - ");
Serial.print("HeatI: ");
Serial.print(hi);
Serial.println("*C");
Serial.println(Time.timeStr());
if(!shutdownButton)
startShutdown();
digitalWrite(ledRelay, LOW);
digitalWrite(fanRelay, LOW);
digitalWrite(heatRelay, LOW);
moistureVirtual()
startExtraction();
startExtraction();
startExtraction();
stopExtraction();
temperatureVirtual();
startHeating();
stopHeating();
stopHeating();
startHeating();
void temperatureVirtual()
void startHeating()
void stopHeating()
void lightingMaster()
if(!lightingButton)
startLighting();
else if (lightingButton)
stopLighting();
if (Blynk.connected()) Blynk.run();
Timer = millis();
growBoxMaster();
erros:
In file included from blynk/BlynkParticle.h:14:0,
from blynkt.cpp:6:
else if (lightingButton);
blynkt.cpp:42:10: error: expected constructor, destructor, or type conversion before '(' token
blynkt.cpp:43:10: error: expected constructor, destructor, or type conversion before '(' token
int humid1;
blynkt.cpp:44:10: error: expected constructor, destructor, or type conversion before '(' token
blynkt.cpp:45:10: error: expected constructor, destructor, or type conversion before '(' token
from blynkt.cpp:6:
CREATE ISSUE
blynkt.cpp:92:1: note: in expansion of macro 'BLYNK_WRITE'
CREATE ISSUE
blynkt.cpp:84:1: note: in expansion of macro 'BLYNK_WRITE'
blynkt.cpp:121:17: error: 'dhtReadings' was not declared in this scope
blynkt.cpp:135:1: error: expected unqualified-id before '{' token
milis = millis();
i always put setup exactly before loop
this is an easy error for you to find and fix
what is milis?
like: defines
blynk_writes()
setup()
loop()
does this solve anything?
sure! at least that is what works for me…
i don’t think it helped… i think its the same errors…
edit: ill try to solve this tomorrow, I’m a zombie from sleeping too little thinking about this ahah
I cant seem to compile it because I dont have the Photon boards library installed in IDE.
I recommend you ditch the Photon device and go for a NodeMCU ESP8266-12F/E clone for like $3… get the 4Mbyte version…
Im just re-writing your code so it compiles on the ESP now… might save you loads of head scratching hah
EDIT: Here you go… this compiles fine on my end on an ESP8266 NodeMCU clone. I’ve chopped out at least 80 lines of repeated code. I also recommend ditching all the Serial prints UNLESS you need them for debugging… I installed SimpleTimer lib so its in line with Blynk standards to control the growboxmaster()…you can see it fires every 2 seconds… you can change that in setup.
#include <DHT.h>
/* DEFINITIONS */
#define DHTPIN 4 // D4 pin input from DHT11
/* VIRTUAL PORTS */
#define UPTIME_vPIN 0
#define MOIST_BRK_PNT_vPIN 2
#define TEMP_BRK_PNT_LO_vPIN 3
#define TEMP_BRK_PNT_HI_vPIN 4
#define SHUTDOWN_BTN_vPIN 5
#define EXTRACT_BTN_vPIN 6
#define LIGHTING_BTN_vPIN 7
#define HEAT_BTN_vPIN 8
#define HUMID_vPIN 20
#define HEATING_LED_vPIN 21
#define LIGHTING_vPIN 22
#define HEATING_vPIN 24
#define EXTRACT_vPIN 25
#define TEMP_vPIN 26
#define SHUTDOWN_vPIN 28
/* LIBRARY CMDS */
SimpleTimer timer0;
SimpleTimer timer1;
/* AUTH CODE BLYNK */
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
/* GLOBAL VAR DEFINE - Enter default values in setup */
bool shutdownButton;
float humid;
float temp;
int moistureBreakpoint;
bool extractionInProgress;
bool extractionButton;
int temperatureBreakpointLow;
int temperatureBreakpointHigh;
bool heatingInProgress;
bool heatingButton;
bool lightingButton;
/* SET PINMODE */
pinMode(DHTPIN, INPUT); //Input for the DHT pin
/* SET DEFAULT VAR VALUES */
shutdownButton = 1;
heatingButton = 0;
lightingButton = 0;
/* START COMMUNICATION */
while (!Serial) {
Blynk.begin(auth, "SSID", "PASS");
/* START LIBRARIES */
dht.begin();
timer0.setInterval(2000L, growBoxMaster);
timer1.setInterval(1000L, sendUptime);
/* DONE SETTING UP */
BLYNK_WRITE(MOIST_BRK_PNT_vPIN) {
moistureBreakpoint = param.asInt();
BLYNK_WRITE(TEMP_BRK_PNT_LO_vPIN) {
temperatureBreakpointLow = param.asInt();
BLYNK_WRITE(TEMP_BRK_PNT_HI_vPIN) {
temperatureBreakpointHigh = param.asInt();
BLYNK_WRITE(SHUTDOWN_BTN_vPIN) {
shutdownButton = param.asInt();
BLYNK_WRITE(EXTRACT_BTN_vPIN) {
extractionButton = param.asInt();
BLYNK_WRITE(LIGHTING_BTN_vPIN) {
lightingButton = param.asInt();
BLYNK_WRITE(HEAT_BTN_vPIN) {
heatingButton = param.asInt();
void sendUptime() {
Blynk.virtualWrite(UPTIME_vPIN, millis() / 1000);
void growBoxMaster() {
dhtReadings();
shutdownMaster();
moistureMaster();
heatingMaster();
lightingMaster();
// Get Readings
void dhtReadings() {
humid = dht.readHumidity();
temp = dht.readTemperature();
if (isnan(humid) || isnan(temp) ) {
return;
Blynk.virtualWrite(HUMID_vPIN, humid);
Blynk.virtualWrite(TEMP_vPIN, temp);
Serial.println("------- ShutdownMaster started -------");
if (!shutdownButton) {
Blynk.virtualWrite(SHUTDOWN_vPIN, 1023);
void moistureMaster() {
if ((humid > moistureBreakpoint) && (!extractionInProgress) && (extractionButton = HIGH)) {
startExtraction();
if ((humid > moistureBreakpoint) && (!extractionInProgress) && (extractionButton = LOW)) {
startExtraction();
if ((humid < moistureBreakpoint) && (extractionInProgress) && (extractionButton = HIGH)) {
startExtraction();
if ((humid < moistureBreakpoint) && (extractionInProgress) && (extractionButton = LOW)) {
stopExtraction();
Serial.print("humid - ");
Serial.println(humid);
digitalWrite(fanRelay, HIGH);
Blynk.virtualWrite(EXTRACT_vPIN, 1023);
Blynk.virtualWrite(EXTRACT_vPIN, 0);
if ((temp < temperatureBreakpointLow) && (!heatingInProgress) && (!heatingButton)) {
startHeating();
else if ((temp < temperatureBreakpointLow) && (!heatingInProgress) && (heatingButton)) {
stopHeating();
else if ((temp >= temperatureBreakpointHigh) && (heatingInProgress) && (!heatingButton)) {
stopHeating();
else if ((temp >= temperatureBreakpointHigh) && (heatingInProgress) && (heatingButton)) {
startHeating();
Serial.print("temp - ");
Serial.println(temp);
void startHeating(){
digitalWrite(heatRelay, HIGH);
Blynk.virtualWrite(HEATING_vPIN, 1023);
Blynk.virtualWrite(HEATING_LED_vPIN, HIGH);
void stopHeating(){
Blynk.virtualWrite(HEATING_vPIN, 0);
Blynk.virtualWrite(HEATING_LED_vPIN, LOW);
Serial.println("------- lightingMaster started -------");
if (!lightingButton) {
digitalWrite(ledRelay, HIGH);
Blynk.virtualWrite(LIGHTING_vPIN, 1023);
else if (lightingButton) {
Blynk.virtualWrite(LIGHTING_vPIN, 0);
timer0.run();
timer1.run();
The pinmode declaration is not in the setup(). That is at least something I saw. Also, I don’t think it’s needed to declare the output pin for DHT, but I’m not sure, I don’t think I do that.
You have Two BLYNK_WRITE(V6). I think you need to find another free pin I assume it can be V5.
void dhtReadings(); <-- remove the “;”, it’s not supposed to be there
Furthermore I see you have a different kind of library to read out the DHT, but this is what I noticed when compiling.
If your head hurts too much, set aside the project for a day or so and continue later. If you try to hard it will come back and bite you in the ass, baby steps
@Jamin the code you posted compiles and is fully functioning with a node mcu ? If so i think ill order one, many thanks man!
@Lichtsignaal i quickly changed the dht library because i wasnt getting steady readings and started doing the structural changes and things got messed up aha when i get home ill look closely on those points you mentioned if i cant get it to compile i think ill order the.nodemcu that @Jamin was talking about since the code is good. its a chance to really study and learn the proper ways to write and how blynk should work
Thanks for the effort and time spent guys, looking forward to share the knowledge when i get to your level ahah cheers
EDIT: @Jamin i dont think its hard to adapt to use a particle photon, i dont know, i havent had a chance to have a proper look to your code but it looks really great. ill try it
@bernas_123, Totally go for it dude! If you can adapt it then go hard… it should be pretty simple too
Just a note, grab the proper DHT library… dont use the adafruit version.
If you do grab a NodeMCU… I have both of these and they’re great… larger one and smaller one
thanks man! I’m trying out a couple, it seems that the some libraries don’t give steady readings, but i think i have to calibrate the dht!
they look great, little amazing machines and the price is incredible comparing to the photons
im also finishing the wiring so that i can try it all, see if it all works fine
cheers man!
hey guys, i’ve been short on time to work on this but i´ve been trying to work on a code but i can’t get it to compile… i had a problem with simpleTimer library, it’s not supported on the web ide so the alternative is the SparkIntervalTimer which is fairly simple to use, but it doesn’t compile anyone know why?
#include "SparkIntervalTimer/SparkIntervalTimer.h"
/* DEFINITIONS */
/* VIRTUAL PORTS */
/* LIBRARY CMDS */
IntervalTimer timer0;
IntervalTimer timer1;
float humid;
float temp;
bool heatingButton;
/* SET PINMODE */
shutdownButton = 1;
heatingButton = 0;
lightingButton = 0;
while (!Serial) {
dht.begin();
timer0.begin(growBoxMaster, 2000, hmSec);
timer1.begin(sendUptime, 1000, hmSec);
void sendUptime() {
dhtReadings();
shutdownMaster();
moistureMaster();
heatingMaster();
lightingMaster();
// Get Readings
return;
startExtraction();
startExtraction();
startExtraction();
stopExtraction();
startHeating();
stopHeating();
stopHeating();
startHeating();
void stopHeating(){
timer0.run();
timer1.run();
errors:
/* DEFINITIONS */
/* VIRTUAL PORTS */
/* LIBRARY CMDS */
float humid;
float temp;
bool heatingButton;
/* SET PINMODE */
shutdownButton = 1;
heatingButton = 0;
lightingButton = 0;
while (!Serial) {
dht.begin();
void sendUptime() {
dhtReadings();
shutdownMaster();
moistureMaster();
heatingMaster();
lightingMaster();
// Get Readings
return;
startExtraction();
startExtraction();
startExtraction();
stopExtraction();
startHeating();
stopHeating();
stopHeating();
startHeating();
void stopHeating(){
timer0.run();
timer1.run();
cheers!
you posted teh code twice. /doh/
what MCU are you using?
Still waiting for the ESP from China?
Not sure how to help you as I have no experience with Particle IDE
