Hi. is there any way to choose two devices at the same in Eventor ? for example if temp on esp8266 go to 50°C then arduino uno pin v1 turn on
thanks
thanks
Can anyone help me ?
Hello. This is not possible at the moment.
thanks for reply. is it possible in the future ?
thanks
Yeap. For sure we’ll implement this.
Thanks. I cant wait for this feauture.
You might need to give them more than two whole weeks
Meanwhile, could you not use Eventor to trigger an otherwise unused Vpin for one device that uses Bridge to trigger the required Vpin on the 2nd device?
thanks for reply
I need brdige sketch for ESP8266 can you help me please ?
thanks
Any Update !!
Can we use Eventor with Tags ?
No updates. Sorry.
no problem
Would be good to have at least the possibility to create multiple eventor widget, one per device?
Please post ideas here… or add your vote to existing ones.
