Hi i using two ESP8266. One for show data from DHT sensor on LCD and another ESP8266 with DHT sensor.
But i need includ to my sketch sending data to Blynk… But i dont know how:( This sketch no sending data to Blynk…
THanks.
#define BLYNK_DEBUG
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WiFiUDP.h>
#include <Wire.h>
#include <BlynkSimpleEsp8266.h> // blynk
#include <SimpleTimer.h> // blynk
#include <DHT.h>
#include <EEPROM.h>
#include <WifiConfig.h>
#include <interval.h>
#include <espnbns.h>
#define DHTTYPE DHT22
#define DHTPIN 2//pin D5
#define FORCE_CONFIG_BUTTON_PIN 3 // pin pro tlacitko na vynucenou rekonfiguraci (RXD)
char auth[] = "75a3e91cbdf1457eea63e9c1";
// Definice obsazeni EEPROM
#define elementSize(type, element) sizeof(((type *)0)->element)
typedef struct
wificonfigarea_t wc; // oblast, vyhrazena pro konfiguraci WiFi
char apiKey[33]; // retezec, obsahujici APIKEY pro ThingSpeak
char server[65]; // retezec, obsahujici adresu Thingspeak serveru
char field[65]; // jmeno datapointu, do ktereho je ukladana teplota
char periode[32]; // perioda ukladani dat [s]
}eepromdata;
WifiConfig wifi; // konfigurace ESP modulu
NBNS nbns;
ESP8266WebServer wwwserver(80); // webovy server
// Initialize DHT sensor
DHT dht(DHTPIN, DHTTYPE, 11); // posledni parametr je k nicemu (uz se nepouziva) - Adafruit upravil knihovnu na autokalibraci rychlosti
float humidity, temp_f; // Values read from sensor
Interval measurement; // interval mezi jednotlivymi merenimi
String nbnsname;
WiFiUDP udp;
// Multicast declarations
IPAddress ipMulti(255, 255, 255, 255);
unsigned int portMulti = 5566; // local port to listen on
void wcb(wificonfigstate_t state)
switch (state)
case WCS_CONNECTSTART:
Serial.println("Starting connect...");
break;
case WCS_CONNECTING:
break;
case WCS_CONFIGSTART:
Serial.println("Starting config...");
break;
case WCS_CONFIGWAIT:
break;
void setup(void)
Serial.begin(9600); // See the connection status in Serial Monitor // blynk
Blynk.begin(auth, "ASUS", "Jersin72"); //insert here your SSID and password
timer.setInterval(20000L, sendUptime);
EEPROM.begin(512); // zahajujeme praci s EEPROM
pinMode(FORCE_CONFIG_BUTTON_PIN, INPUT_PULLUP); // RXD slouzi jako vstup tlacitka
int force = digitalRead(FORCE_CONFIG_BUTTON_PIN);
wifi.begin(offsetof(eepromdata, wc), force, wcb); // startujeme pripojeni
Serial.println(getOurIP());
dht.begin(); // inicializujeme senzor
while (! udp.begin(portMulti))
Serial.print("+");
yield();
nbnsname = getEEPROMString(offsetof(wificonfigarea_t, devname), elementSize(wificonfigarea_t, devname));
if (nbnsname.length() > 0)
nbns.begin(nbnsname.c_str());
void loop(void)
nbns.poll();
gettemperature();
void gettemperature()
if (measurement.expired())
// udp.flush();
// Reading temperature for humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
for (int i=0; i < 5; i++)
yield();
humidity = dht.readHumidity(); // Read humidity (percent)
if (!isnan(humidity))
break;
// humidity = dht.readHumidity(); // Read humidity (percent)
yield();
temp_f = dht.readTemperature(false);
if (!isnan(temp_f))
break;
// temp_f = dht.readTemperature(false); // Read temperature as Celsius
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(temp_f))
if (isnan(humidity))
Serial.println("Failed to read humidity from DHT sensor!");
if (isnan(temp_f))
Serial.println("Failed to read temperature from DHT sensor!");
String result;
result = ":7777;";
result += temp_f;
result += ";";
result += humidity;
result += ";";
udp.beginPacketMulticast(ipMulti, portMulti, getOurIP());
udp.print(result);
udp.endPacket();
Serial.println("Data sent...");
measurement.set(6000); // nastavime novy interval mereni
// measurement.set(2 * dht.getMinimumSamplingPeriod()); // nastavime novy interval mereni
// EOF
void sendUptime() // blynk
float h = dht.readHumidity();
Blynk.virtualWrite(4, t); // virtual pin
Blynk.virtualWrite(5, h); // virtual pin
