Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Ok, so I am trying to create a little vehicle. 2 dc motors will drive the vehicle. 1 dc motor will engage a conveyor belt system and a servo will be used to raise and lower the conveyor belt system. I have connected to my HM-10 Bluetooth module from my phone and have been able to control the servo with it. I am having trouble controlling the dc motors that are connected to an Adafruit v2.3 motorshield. The dc motors spin when I upload a test code that varies their speed and direction, but I can’t control them with my phone. Take a look at my code and see if there’s anything wrong in there. I’m confident that my wiring is done correctly. At this point, I’m just not sure what’s wrong with it but it has to be Blynk related (or so I am thinking) or the code associated with it. Any advice would be great thanks!
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
#include <Servo.h>
Adafruit_MotorShield AFMS=Adafruit_MotorShield();
Adafruit_DCMotor *motor1=AFMS.getMotor(1);
Adafruit_DCMotor *motor2=AFMS.getMotor(2);
Adafruit_DCMotor *motor3=AFMS.getMotor(3);
Servo servo1;
Serial.println("Adafruit Motorshield v2 - DC Motor test!");
AFMS.begin();
servo1.attach(6);
motor3->setSpeed(100); //digging arm speed test number
//LEFT MOTOR FORWARD
BLYNK_WRITE(V1) {
int pinValue=param.asInt();
Serial.print("Motor 1 Forward: ");
Serial.println(pinValue);
if(pinValue==1) {
motor1->run(FORWARD);
if(pinValue==0) {
motor1->run(RELEASE);
//RIGHT MOTOR FORWARD
BLYNK_WRITE(V2) {
Serial.print("Motor 2 Forward: ");
if(pinValue==1) {
motor2->run(FORWARD);
if(pinValue==0) {
motor2->run(RELEASE);
//LEFT MOTOR BACKWARDS
BLYNK_WRITE(V3) {
Serial.print("Motor 1 Backwards: ");
if(pinValue==1) {
motor1->run(BACKWARD);
if(pinValue==0) {
//RIGHT MOTOR BACKWARDS
BLYNK_WRITE(V4) {
Serial.print("Motor 2 Backwards: ");
if(pinValue==1) {
motor2->run(BACKWARD);
if(pinValue==0) {
//MOTOR SPEED
BLYNK_WRITE(V5) {
Serial.print("Motor Speed: ");
motor1->setSpeed(pinValue);
motor2->setSpeed(pinValue);
//SERVO UP DOWN
BLYNK_WRITE(V6) {
servo1.write(param.asInt());
//DIG FORWARD
BLYNK_WRITE(V7) {
Serial.print("Motor 3 Forward: ");
if(pinValue==1) {
motor3->run(BACKWARD);
if(pinValue==0) {
motor3->run(RELEASE);
//DIG BACKWARDS
BLYNK_WRITE(V8) {
Serial.print("Motor 3 Backwards: ");
if(pinValue==1) {
if(pinValue==0) {
//EMERGENCY STOP
BLYNK_WRITE(V9) {
Serial.print("Emergency Stop: ");
if(pinValue==1) {
//if(pinValue==0) {
// motor3->run(RELEASE);
