I have an Arduino Mega 2560 and a Adafruit Fona 808 shield.
In the hardware list I saw this combination should work, but I can’t get it working yet.
When I use the Adafruit test the serial monitor says “FONA is OK” and “Found FONA 808 (v2)” and I can run the test cases like read the sim ID, etc.
So I assume the wiring, available power etc all is OK.
Even though I am using the Mega I am using SoftwareSerial since Adafruit Fona currently does not support hardware serial.
However, when I use the SIM800_SIM900 example code and populate my RX and TX pins it unfortunately does not work.
The serial monitor says
What could be a next step for me to get this up and running?
I have tried connecting the Adafruit Fona to all Rx/TX pins on the Mega but neither worked. The AT debug fails on all baud rates.
@oudevolvo I suggest you ask over at the Adafruit forums as this is their product. Once you have it communicating with the Arduino properly, then we can better assist with Blynk.
Thanks, done that.
However, the thing is I got the Fona 808 working with my Mega using the FONAtest sketch and the Adafruit library. It says:
FONA test basic
Initializing… (may take 3 sec)
Attempting to open comm with ATs
Then a couple of
—> AT
Etc
And in the end
SIM 808 R14.18
OK
FONA is OK
Found FONA 808 (v2)
And then shows the IMEI.
Battery charge is 100% and using that test sketch I can request a URL (and get a response), read SMS messages from SIM.
But let’s see what comes from the Adafruit forums.
Will keep you posted.
Hello, I’m having the same problem with an arduino UNO and a fona808. I tryed to modify the TinyGsmClientSIM800.h file and I switched RX and TX. Do you have any other suggestion?
