Guys
I am working through Blynk Sketch Builder
I am getting on fine and beginning to understand the the code
However when I upload any type of notification code I do not receive any notifications
I am using a Wemos mini I have a resistor 10K between pin D2 and 5v
I also have a momentary push switch between Gnd and D2
I have attached a screen shot of what appears in the serial monitor as with previous advice I have removed the IP address I do get on line but I do not get the emails ( gmail account )
Thanks for the reply Idb that was my 3rd attempt in the previous attempts it was showing online on the serial output but when I pushed the switch no response was indicated on the serial monitor
With no power to the board I checked the operationale of the switch with my multimeter set to the buzzer the switch is operating as it should
Thanks oldvolt
Hi Pete & Idb and all
What I found out that the push switch should have went across pin 4 and ground of my Wemos D1 mini but in the sketch it’s coded as D2 if this makes sense
I am going to Google to try and find out the pin relationship between an uno R3 and Wemos mini
D1
Thanks again oldvolt
