Hi @Dmitriy
I am a little confused about server release deployment on Blynk’s servers.
Are Blynkers guinea pigs for the releases or is deployment for Blynk more involved than I think it is?
It depends on release. Usually we deploy right after release. But in case release doesn’t have nothing critical or urgent it could be delayed or even skipped for next version.
You said that old method is also works, but in API documentation it changed (Getting values from pin was http://blynk-cloud.com/auth_token/pin/pin and now it http://blynk-cloud.com/auth_token/get/pin)
And when I try to write pin value via PUT http://my.local.server/auth_token/update/pin + parameters I have 404 error on local server 0.18.2. Via GET it works.
