Blynk+Esp8266+Arduino UNO
Hey!
I am a George 13yr old maker from INDIA, who wants your help in making a weather station with BLYNK app…
I am intending to make a weather station with Arduino Uno and esp8266 (ESP8266EX AI CLOUD) with blynk as Weather Moniter …I 've been searching past the weeks on tutorials regarding connecting esp8266ex with arduino but could’nt find a appropriate one!
https://www.google.co.in/search?q=esp8266ex&rlz=1C1CHBF_enIN713IN713&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiD0YXn3svPAhWMP48KHZYRDE8Q_AUICCgB&biw=1366&bih=613#imgrc=dQaxnyRfDmzvqM%3A
Some say you need voltage divider where others say you need to flash esp…
I cant stake my esp8266 as my father cant afford buying a new one to me!
I hope you understand my difficulties as 13yr old kid!!!
Please help me out!
Thanks in advance
from LITTLE Brother
:smiley:
I have a better alternative for you. Namely the Wemos D1. It has an integrates usb port so you can program it directly from the arduino ide without worrying about stupid voltage dividers and such.
If the costs are an issue, I’d be happy to send you my spare one. Let me know if you are interested.
And I might even ask the wonderful people of the Blynk team to donate a couple bucks to cover the mail costs :wink:
Thanks buddy!
I appreciate you kind heart!
I as i have already puchased Arduino, I would like to get a tutorial in using blynk app +esp8266+arduino
Can we have a chat?
It’s not very difficult to get things working with the ESP. On this forum there is very comprehensive information about what you want to achieve. The transmit from the UNO to the Rx of the ESP does have to be pulled down to 3.3v with some sort of voltage divider, a simple resistor will work in most cases.
Basically:
But of course the Tx/Rx go to the appropriate pins on your Arduino, not to digital pins as depicted in the picture above.
One more thing, if you are going to debug this, you need to enable Software Serial for debug output. You could also use software serial to attach the ESP to the Arduino, but that is really unstable.
Some sort of voltage divider???
Can you explain(resistance of the resisters)?
Thanks in advance!:slight_smile:
@Costas @vshymanskyy @tzapulica @Dave1829
Could you please help the guy. I’m not very good with ESPs, especially when using them as a shield.
He is participating in some sort of an important contest, representing his whole state(!) next Tue.
@george:
Please add more info on your project( sensors and so on) and what’s your status
Hi @george,
Please take a look at one of the many voltage dividers available online such as this one http://www.raltron.com/cust/tools/voltage_divider.asp
Enter 5 in the Input Voltage box and 3.3 in the Output voltage box. You then enter the resistor value you might have for R1 and press the Compute button to see if you have the required resistor for R2.
Equally you can enter a value in R2 to establish the value of R1.
3.3 and 5 are not exact figures and neither are the resistors as they all have tolerances. A 2K resistor at R2 gives 1030.3 ohms value for R1. Removing the 3.3 output voltage and changing the 1030.3 on computation gives 3.333 volts which should be fine for the RX pin on the ESP.
Maybe get to this stage and then we can move on.
If you only have one ESP it isn’t worth the risk of not using a voltage divider. It might run for 10 minutes, 10 hours or 10 weeks without one but equally it might go “puff” in the “blink” of an eye.
Hopefully you have the correct firmware on the ESP as many do these days.
You will need to use the following sketch for the Arduino but only after setting up the voltage divider https://github.com/blynkkk/blynk-library/blob/master/examples/Boards_WiFi/ESP8266_Shield/ESP8266_Shield.ino
It is available in the Arduino IDE.
As you have a very short time to get this up and running I will let you work on the voltage divider whilst I look at the changes required for the sketch to work with an Uno.
Here is the required sketch with a couple of lines modified for use with an Uno. Pin 2 on the Uno is for receiving (rx) data from the ESP and pin 3 on the Uno is for transmitting (tx) data to the ESP.
So pin 2 Uno (rx) goes to the tx pin on the ESP and pin 3 Uno (tx) goes to the rx pin on the ESP. Voltage divider goes between Uno pin 3 and ESP rx pin.
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use ESP8266 Shield (with AT commands)
 * to connect your project to Blynk.
 * Note: Ensure a stable serial connection to ESP8266!
 *       Firmware version 1.0.0 (AT v0.22) is needed.
 *       You can change ESP baud rate. Connect to AT console and call:
 *           AT+UART_DEF=9600,8,1,0,0
 *       In general, Soft Serial may be unstable.
 *       It is highly recommended to switch to Hard Serial.
 * Change WiFi ssid, pass, and Blynk auth token to run :)
 * Feel free to apply it to any other example. It's simple!
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set console baud rate
  // Set ESP8266 baud rate
Hey!
@Costas @Lichtsignaal ichtsignaal
I finished wiring(built a 3.3v regulator) and folowed[ Lichtsignaal] wiring he commented above!!!
So now can use esp8266 without any flashing ,by just connecting it to arduino and following your code???
@george you will need to enter your token in the sketch.
Try it but ensure you have Serial Monitor open before you upload the sketch and provide us with any messages you see in Serial Monitor.
Be prepared for “failed to echo” messages.
No, it helps more people if all questions and answers are kept in one place i.e. here on the Blynk Community site.
If you have the voltage divider set up then it is safe for you to upload the sketch. It might not work but you shouldn’t damage the ESP. Provide any messages that appear in Serial Monitor by copying and pasting them in this thread.
Yes, it should work now. As Costas mentioned, keep the Serial monitor open (ctrl-shift-m on Windows I believe) and turn it on. If you didn’t do any flashing to the ESP it should run the standard AT firmware and act as a shield. In the Blynk sketch Costas provided you need to edit the Wifi network, SSID and Authentication token for connecting to Blynk servers.
the guys have done a tremendous job of explaining everything so clear your head, and go through their instructions as a check list. tinkering with electronics can be frustrating but also very rewarding.
you might also want to google some of the stuff for more details, it will help you learn better how things are linked and how they are supposed to work together.
the keypoints they mentioned are:
  • make sure your ESP chip runs the AT firmware
  • make sure you have a proper divider
  • make sure you have all conenctions as instructed
  • start your modules and make sure they can communicate
  • up to this point, don t even bother with Blynk (it’s easy to add after anyway, jsut use the example they provided)
  • if all ok, add blynk, sensors, etc
Also here s an article related to this, in case there is anything more useful there http://www.instructables.com/id/Cheap-Arduino-WiFi-Shield-With-ESP8266/?ALLSTEPS
Good luck
Is it UNO ESP
RX----------------TX
TX----------------RX
             OR
   UNO              ESP
  RX------------------RX
  TX-------------------TX
I am confused! Some tutorials say rx to rx and tx to tx!!
Reply faaast!!!
Thanks in Advance!
:wink:
This is correct as per the 3 or 4 references by different Blynkers in this thread.
Occasionally the internet has inaccurate information and there is a reason sometimes the connections are quoted differently, but you don’t need to know about that at this stage. Ask later if you are interested.
We are all taking an active overview of what you are doing so if any Blynkers suggest anything that is obviously wrong it will be picked up promptly and corrected i.e. you can take what is quoted in this thread to be 100% accurate and ignore the general internet for now.
C:\Users\george\Documents\Arduino\bl_commu\bl_commu.ino:33:25: fatal error: ESP8266_Lib.h: No such file or directory
Please provide the link to the library!!!
@george you didn’t install the libraries correctly. There are now 5 “Blynk” libraries that have to be installed manually and not through Arduino IDE Boards manager.
See here for details https://github.com/blynkkk/blynk-library/releases/tag/v0.3.10
I did warn you back in post 10 that you were likely to see this, now the fun starts.
There are posts on this site about “echo” but basically it means you have a problem.
Could be badly wired circuit so it is worth you checking this.
The other two major reasons for this error is a problem with the different baud rates and the wrong firmware on the ESP.
Let us all look for decent “echo” answers.
As @Costas says, it could be a firmware issue. The only way to check if you have the correct firmware is to hook up the ESP Tx/Rx lines to a serial port and directly check with AT commands to see if that is the case.
Bad wiring is easily enough troubleshooted. Did you hook up both CH_PD and VCC to 3.3v?
