Blynk.connect() timeout does not match the setting. Blynk v1.3.2
The actual timeout when trying to connect to the server is much longer than the one I specify in the function.
In my example, the timeout is set to 2 seconds, but in reality it is about 14 seconds.
The problem is that during this time the controller does not perform the necessary other tasks, and this is very important.
I provide the code and data from the port monitor below.
#define BLYNK_TEMPLATE_ID      "___"
#define BLYNK_TEMPLATE_NAME   "___"
#define BLYNK_AUTH_TOKEN      "___"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "___";
char pass[] = "___";
int blynk_timeout_seconds = 2;                // Timeout value for the Blynk.connect(timeout) command. The library default is 18 seconds
long check_connection_seconds = 30;           // Check the connection every 30 seconds
int wait_between_wifi_attempts_millis = 500;  // How long do we wait (in milliseconds) between each WiFi connection attempt
int max_wifi_connect_attempts = 15;           // How may times we try to connect to WiFi before giving-up
  Serial.begin(74880);
  Blynk.config(BLYNK_AUTH_TOKEN); // When we try to connect to Blynk, these are the credentials we'll use
  Connect_to_WiFi();              // Call the function that attempts to connect to WiFi
  timer.setInterval(check_connection_seconds * 1000L, Check_Connections);
  Connect_To_Blynk();             // Call the function that attempts to connect to Blynk
//  if (WiFi.status() == WL_CONNECTED) // Commented-out for testing
    if(Blynk.connected())
      // Only execute Blynk.run if we are connected to Blynk
  timer.run();  // feed the timer process
 void Connect_to_WiFi()
  Serial.println(F("Connecting to Wi-Fi..."));
  int wifi_attempt_count = 1; // used to track how many times we've tried to connect to WiFi
  if (WiFi.status() != WL_CONNECTED)
      WiFi.begin(ssid, pass); // connect to WiFi
  while (WiFi.status() != WL_CONNECTED  && wifi_attempt_count < max_wifi_connect_attempts) // Loop until we've connected, or reached the maximum number of attemps allowed
    Serial.print(F("Wi-Fi connection - attempt # "));
    Serial.print(wifi_attempt_count);
    Serial.print(F(" of "));
    Serial.println(max_wifi_connect_attempts);
    delay(wait_between_wifi_attempts_millis);
    wifi_attempt_count++;
  // We reach this point when either we're connected to Wi-Fi, or we've reached the maximum number of attempts.
  // We need to do differnet things, depending which it is...
    // We get here if we're connected to WiFi
    WiFi.mode(WIFI_STA); // Put the NodeMCU in Station Mode, so it doesn't broadcast its SSID
    Serial.println(F("Successfully connected to Wi-Fi"));
    // we get here if we tried multiple times, but can't connect to Wi-Fi. We need to go into standalone mode...
    Serial.println(F("Failed to connect to Wi-Fi"));
void Connect_To_Blynk()
//  if (WiFi.status() == WL_CONNECTED)// Commented-out for testing
    // if we're connected to WiFi then try to connect to Blynk...
    Serial.println(F("Attempting to connect to Blynk..."));
    Blynk.connect(blynk_timeout_seconds*1000);
    Serial.println(F("Blynk.connect() attempt ended"));                         // For testing
      Serial.println(F("Blynk connection attempt succeeded - connected"));       // For testing
      Serial.println(F("Blynk connection attempt failed - not connected"));     // For testing
void Check_Connections() // Called with a timer
  Serial.print("Checking connections.. ");
    // We get here if we are connected to WiFi...
    Serial.print("WiFi Okay,  ");
    // now check if we're connected to Blynk...
      Serial.println("Blynk Okay");
      // We get here if we are connected to WiFi, but not to Blynk, so try to re-connect...
      Serial.println("Blynk not connected");
      Connect_To_Blynk();
    // We get here if we aren't connected to WiFi & Blynk, so try to re-connect...
    Serial.println("WiFi not connected");
//    Connect_to_WiFi(); // Commented-out for testing
    Connect_To_Blynk();
Port monitor. It can be seen that there are two attempts to connect to the Blynk server (ports 80 and 8080), each attempt takes about 7 seconds, the total time is about 14 seconds.
19:35:55.982 ->     ___  __          __
19:35:55.982 ->    / _ )/ /_ _____  / /__
19:35:55.982 ->   / _  / / // / _ \/  '_/
19:35:56.029 ->  /____/_/\_, /_//_/_/\_\
19:35:56.029 ->         /___/ v1.3.2 on ESP32
19:35:56.029 ->
19:35:56.029 ->  #StandWithUkraine    https://bit.ly/swua
19:35:56.029 ->
19:35:56.029 ->
19:35:56.029 -> Connecting to Wi-Fi...
19:35:56.123 -> Wi-Fi connection - attempt # 1 of 15
19:35:56.639 -> Wi-Fi connection - attempt # 2 of 15
19:35:57.140 -> Successfully connected to Wi-Fi
19:35:57.140 -> Attempting to connect to Blynk...
19:35:57.140 -> [1187] Connecting to blynk.cloud:80
19:36:03.992 -> [8056] Connecting to blynk.cloud:8080
19:36:11.026 -> Blynk.connect() attempt ended
19:36:11.026 -> Blynk connection attempt failed - not connected
