I copied the example code for the Bluetooth Servo using Hc-05. I downloaded the app on Android. The phone’s settings show the HC-05 is connected. I made a new project. Selected Uno board and bluetooth connection. I made a slider value 0-180 and set it as V3. Put in my auth code and everything. I do notice that the <BlynkSimpleSerialBLE.h> is not black rather than orange like the rest of the library names. The code uploaded to the board fine. When I click the play button on the app, I get told the device is offline. What am I doing wrong?
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino with HC-06/HC-05
Bluetooth 2.0 Serial Port Profile (SPP) module
to connect your project to Blynk.
Note: This only works on Android! iOS does not support SPP :(
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
NOTE: Bluetooth support is in beta!
Rotate a servo using a slider!
App project setup:
Slider widget (0...180) on V3
#include <Servo.h>
char auth[] = "e7c17d6a8ae446cab9975d01d35e46af";
SoftwareSerial SerialBLE(10, 11); // RX, TX
Servo servo;
BLYNK_WRITE(V3)
servo.write(param.asInt());
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
servo.attach(9);
