i kindly ask anybody on this forum, who has a working and stable system using bluetooth with blynk, to share the details with me (like: exactly what bluetooth module are you using, where did you bought it, what mcu, phone, android version, sketch, etc)
i have problems using blynk with ble (bluetooth low energy 4.0). upt to now, for 2 weeks i try to figure out what could be the problem, discussed with several founder members, tried all kind of things, nothing helped.
a lots of times the app can not find the ble module
when finds it, sometimes can not connect, or becomes unresponsive (just displays āconnectingā¦ā forever)
when connects, the data transfer between the arduino and phone is working, but sometimes just after a few seconds it stops receiving any data (although apparently remains connected)
if i put the app in background with an working connection, the next time i open it, can not connect, no matter what i try (restart project, restart the app, etc)
when i restart the app, the paired ble module always disappears. although the ble widget is still blue (indicating that it is paired), when i click on the widget, the list is empty, no devices are shown)
Well I know you asked for anyone with a stable system⦠but apparently that does not exist
However I will share my recent (a few days ago) tests using the Light Blue Bean; Turns out I was getting almost the exact same issues as you⦠I thought it was the Bean, but now I think not so much.
I set up the test sketch with the ZeRGBa Widget, a Display Widget for uptime count in seconds and a Slider for controlling a PWM pin.
The Bean was powered by external LiPo battery (not the coin cell).
Not always detecting the Bean.
Not always connecting, or taking forever (must cancel and keep trying).
When connected, I was able to run the ZeRGBa to control the built in RGB OK (really the only thing that did work properly).
If I used a slider to control another LED on a PWM pin, it would work if I slowly faded up and down, sometimes, but usually locked up when on full and I had to disconnect and reconnect again.
Usually when that ālockupā happened, after reconnect, the uptime counter would go into overtime, as in microseconds instead of seconds, requiring a power cycle of the Bean as well.
I stopped fiddling with it after that⦠the fun was lost
Sorry @Gunner, for LBB we could never get stable result, so it is marked as āsoon availableā in https://github.com/blynkkk/blynkkk.github.io/blob/master/SupportedHardware.md
It is very hard to get something really solid stable with that amount of hardware we have on the market.
Weāre also hoping for the community help in this direction
@Tokylabs, no, unfortunately i could never find what the problem was. i had some conversations with @BlynkAndroidDev and @vshymanskyy about these issues, but they said that bluetooth devices were working fine on their test. based on the debug log files and other information i sent from my phones they could not identify the problems i had.
this was several months ago, and in the meantime i had to advance with my project, so i had to find another solution for communication. i switched to wemos d1 mini pro, and using wifi.
however, it seems that after all this is not an isolated case, because i talked with other members on the forum, and they reported very similar problems:
and right now also @Tokylabs and @Gunner experiencing very similar problemsā¦
@wanek Iām curious (having suffered from issues myself). What log files did you send exactly?
@vshymanskyy / @BlynkAndroidDev, et al: Iād love to help, these issues should be trivial to track down - I can get easily my Arduino device to log every piece of BLE communication to the serial monitor. If I could get my phone to log every piece of BLE communication to a logfile it would be simple to check these against each other to pinpoint these issues. Is this possible?
Or even better - some sort of open source / dev access on the app itself? I realise you guys have an IP interest here and a living to make - but honestly solving bugs are a bigger problem than any piracy issues. Heck, Iām more than happy to buy you guys a couple of Adafruit feather boards and send over an old android phone if it means youāll take a look
Iāve made additional logging build for BLE issues: https://drive.google.com/open?id=0B9c7bWQmIMfHMTRQZkF1TE1YTWs. If you could try it with your BLE boards and reproduce your bugs - you can send a log file from about screen. Your help would be appreciated.
That part I understood, but I didnāt realize it was removed as of last App update⦠until I just tried to power up my project and experiment with servos and the servo library on the PWM pins, instead of the failed direct pin manipulation. But now it pops up āUnknown Projects Hardwareā and I canāt run it
This darn LBB has ābeenā a disappointment from the beginning⦠Marketed as multi-platform, but first year only Apple connectivity, now finally Windows but with a lot of hoops.
Then a week ago I discovered that I could finally do āsomethingā with it, even if glitchy, using Blynk⦠I know it is not official or stable, but can you please bring it back (in the hardware list) perhaps as āNoted as Unstableā option until you get it finalised?? Then perhaps I can also contribute to the additional log tests, if that would help?
by the time i sold nearly all my different ble / bluetooth modules, because i could not use them
currently i have just a adafruit feather and a hc-08 module. eventually i can do some test on those when i will have some free time.
what i wonder, it wouldnāt be better to have some basic ātestingā sketches and procedures, and use those for debug? this way everyone could have more or less similar testing environment, with less variables.
for example, to create and share a blynk app, and also a sketch for debug (it should contain various widgets to send and also to receive data). then everyone who willing to test, could use exactly the same setupā¦
@wanek I solved my problem, thanks a lot for your extensive answer.
In my case, the problem was that I was using Xiaomi as Android device, and i didnāt accepted the GPS permission which is needed to use the BLE widget.
Once is accepted, everything is smoothly connected.
@BlynkAndroidDev Somehow, after installing your latest VLC patch, I got my LBBean back in the devices list (still shows 2.11.0)
So I am trying it out with virtual pins on everything but the button. So far so good⦠as long as I donāt try to utilise any PWM pins much higher than around 25% duty cycle⦠either with PWM or servo library, as that eventually locks up the LBBean. I will have to test if that issue also exists without a Blynk sketch.
Anyhow⦠my question is, if I install your LOG patch⦠will I loose my LLB device option again??
Aaa itās due to several flags that enable support for log, they also enable support for debug hardware boards ) Video build has also log support, so there should be no problems
Iāve updated the build due to recent release and also added some additional logging for handling serial Bluetooth issues and connectivity issues. It has much bigger size than the previous one (due to now better video support) - if it is too large you could use another one build (it should be supported by most devices): https://drive.google.com/open?id=0B9c7bWQmIMfHb1l6djdxa1BqdXc
@BlynkAndroidDev Regarding my LLBean test, after leaving it run whilst I sleep, it stayed stable; The only thing I noticed is that battery level and voltage never change, even though they are called every second in the script. Other sensors, RGB LED, button, potentiometer graph, all continued to work without issue.
So anyhow, I had to uninstall Blynk in order to get your LOG patch to install⦠but upon restarting Blynk⦠the LLBean was automatically reconnected and continued showing uninterrupted uptime
However within a few seconds of adjusting the servo (small servo on separate PSU)⦠the board locked up, requiring a power cycle. But then it reconnected automatically again!! Wow⦠many improvements here already!
The original LLB⦠after their extremely long delay in supporting Android and Windows (despite marketing as Multi-Platform), I doubt I will invest in another from them.
@vshymanskyy So now that I have LBB back in the hardware options, what (if anything) can I do to assist Blynk with, as far as stability/functionality troubleshooting with it and other Bluetooth and BLE devices?
Aside from the LBB, I also have an UNO setup with a JY-MCU (HC-06?) module that I am testing with. I even have a gomcu HC-05⦠yep, all the latest gear - circa 2012
