Hey,
I tried implementing a smart roof light at my house. I had successfully implemented it with the zeRGBa widget and also made it turn on and off using Alexa. Now I want help in added fade in and fade out effects during turn on and turn off. as delay blocks can’t be used here. Could someone help on how to go forward with it.
I have used a NodeMCU and couple of TIP31c mosfets to control them.
CODE
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//#include <SimpleTimer.h>
#include "WemoSwitch.h"
#include "WemoManager.h"
#include "CallbackFunction.h"
#define VPIN V2 //Use a unique virtual pin for each device using the same token / dashboard
char auth[] = "******"; //Get token from Blynk
//on/off callbacks
void lightOn();
void lightOff();
WemoManager wemoManager;
WemoSwitch *light = NULL;
boolean LampState = 0;
boolean SwitchReset = true; //Flag indicating that the hardware button has been released
int switchState = 0;
const int RelayPin = D4; //Relay switching pin. Relay is pin 12 on the SonOff
const int RedPin1 = D0;
const int RedPin2 = D5;
const int GreenPin1 = D1;
const int GreenPin1 = D6;
const int BluePin1 = D2;
const int BluePin2 = D7;
int Red = 0;
int Green = 0;
int Blue = 0;
char ssid[] = "****";
char pass[] = "*****";
BLYNK_WRITE(V4) // zeRGBa assigned to V4
// get a RED channel value
Red = param[0].asInt();
// get a GREEN channel value
Green = param[1].asInt();
// get a BLUE channel value
Blue = param[2].asInt();
if (LampState)
{ analogWrite(RedPin1, Red);
analogWrite(GreenPin1, Green);
analogWrite(BluePin1, Blue);
analogWrite(RedPin2, Red);
analogWrite(GreenPin2, Green);
analogWrite(BluePin2, Blue);
pinMode(RelayPin, OUTPUT);
WiFiManager wifi; //WiFiManager intialization.
wifi.autoConnect("Roof Light"); //Create AP, if necessary
wemoManager.begin();
// Format: Alexa invocation name, local port no, on callback, off callback
light = new WemoSwitch("Roof Light", 102, lightOn, lightOff);
wemoManager.addDevice(*light);
pinMode(LED, OUTPUT);
//pinMode(TacSwitch, INPUT_PULLUP);
digitalWrite(RelayPin, LOW);
digitalWrite(LED, LOW);
ArduinoOTA.setHostname("Roof Light");
Blynk.config(auth);
ArduinoOTA.begin();
Blynk.virtualWrite(VPIN, HIGH);
Blynk.syncVirtual(VPIN);
BLYNK_WRITE(VPIN) {
if (switchState != param.asInt()) {
if (LampState == 1) {
lightOff();
else {
lightOn();
switchState = param.asInt();
void lightOn() {
Serial.println("Switch 1 turn on ...");
digitalWrite(RelayPin, HIGH);
// Setting it to a specific colour.
analogWrite(RedPin1, 1023);// Red
analogWrite(RedPin2, 1023);//
analogWrite(GreenPin1, 425);
analogWrite(GreenPin2, 425);// Green
analogWrite(BluePin1, 0);
analogWrite(BluePin2, 0);// Blue
LampState = 1;
Blynk.virtualWrite(VPIN, HIGH); // Sync the Blynk button widget state
void lightOff() {
Serial.println("Switch 1 turn off ...");
analogWrite(RedPin1, 0);// Red
analogWrite(RedPin2, 0);//
analogWrite(GreenPin1, 0);
analogWrite(GreenPin2, 0);// Green
LampState = 0;
Blynk.virtualWrite(VPIN, LOW); // Sync the Blynk button widget state
void ToggleRelay() {
LampState = !LampState;
if (LampState) {
lightOn();
else lightOff();
wemoManager.serverLoop();
ArduinoOTA.handle();
