Zombie widgets keep virtual pins busy
I am finding that if I delete a widget, it sometimes reappears a few minutes later in its former location. This happened with an LED widget just recently. Further, it seems to tie up any virtual pin it was attached to until it reappears and is deleted again. This slows debugging considerably. I haven’t found a way around this yet.
PJ
Hello. Is that iOS or Android?
Hi, it’s on iOS 9.3.2. Blynk version 2.4 I think.
Ok. this should be fixed in next version. Thank you for reporting and sorry for inconveniences.
I haven’t seen a widget disappear and return yet, but I am running v2.5.4 and have a pin showing as busy with no usage in the app. I have destroyed my working app and spent all day yesterday going through code looking for anything else that could be tying the pin up. I haven’t found anything.
Is there a way to free up this pin?
I am running IOS 9.3.5
I think logout and login should resolve your issue.
Logging out and back in resolved the busy issue. Are there any future plans for a numerical keypad widget?
Sorry for the original post, this was the first Google stop, the second had the log off solution. Thanks for the quick reply.
