ZeRGBa Widget
Hello I would like in a contrary function ZeRGBa Widget
Could you please explain in more details. i don’t understand your question.
Mode selection buttons …
How about few small programmable switches (radio buttons) directly on the ZeRGBa Widget ?
Say if
1st switch is selected -> Normal operation lit the selected RGB color.
2nd switch is selected -> Disco Mode, RGB Lights Flash with pre-defined colors
3rd switch is selected -> Lights breathing
etc …
Basically 1 more parameter for the ZeRGBa widget and can be customized with the virtual pins.
@Pavel Does this make sense ??
