zeRGBa pin problem
Hello, when I try to use the RGB widget I cannot pick a pin. When I try to choose it nothing happens. I’m using a arduino- mega with a Ethernet shield
you are not alone , the latest android App has this problem and they said fixed already when next update comes.
workaround is to uninstall Blynk app and the install Blynk Beta V RC10 (Serach APk apps websites you will find it!!)
after that login to you dashboard , set the correct pins test it. then you can update normally from Googlr Play store.
i have done the same and working fine for me.
