it would be great to have the possibility to superimpose widgets and to have a Z index property to put a widget on top/bottom to show/hide it
for example :
blynk.setproperty(V0, ‘zindex’, 2)
thanks a lot
Bruno
for example :
thanks a lot
Bruno
Hello. All widgets on mobile and web supports show/hide and enable/disable via setProperty. Also, you may consider using Pages to hide/show the sections of the UI.
Hi Dmitriy, thank you for your answer,
yes but the main the main idea of the z index is to allow to stack widgets a the same place to pop or push one onto the others
for example : a button will replace a LED, then turn into a label…
Yes, I know, however this is exactly why Pages were done - you can make a dynamic content/view base on it. for exmaple, you can decide what page view to show with setProperty.
Yes I know Pages and it is a great feature
but to be more specific can you please consider this panel :
thank you
I’ve designed some cool UIs in Visual Basic (many years ago, when VB was ‘the thing’) and it’s very easy to get into a lot of trouble when stacking controls.
The mobile app is design to prevent any app overlap, so you’d need to change that, and then have a way of positioning and switching to each of the stacked widgets in edit mode.
I’m guessing that this would be a significant redesign of the mobile apps, would probably be a nightmare when it comes to trying to diagnose and support users who are seeing weird results, or their widget isn’t working because it’s hidden behind something else.
I agree that this type of feature could be good in some situations but personally I don’t think it’s the way to go for the Blynk app.
Hi Pete,
I agree that the major difficulty is to add widgets stack management in the app editor
this done this would give a nice and powerful tool for developers, no more complicated to use as the image library widget for instance
Bruno
