Ws2812 rainbow loop
Hey, so I’m working on an app that controls my ambient lighting. This is my code:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Control a color gradient on NeoPixel strip using a slider!
  For this example you need NeoPixel library:
    https://github.com/adafruit/Adafruit_NeoPixel
  App project setup:
    Slider widget (0...500) on V1
#include <Adafruit_NeoPixel.h>
char auth[] = "1478b535924649d184cc223a944c0051";
char ssid[] = "Hope Siebzehn AP";
char pass[] = "47275552990710462457";
#define PIN D1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if (WheelPos < 85) {
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if (WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
BLYNK_WRITE(V1)
  int shift = param.asInt();
  for (int i = 0; i < strip.numPixels(); i++)
    strip.setPixelColor(i, Wheel(shift & 255));
  strip.show();
BLYNK_WRITE(V2) {
  Serial.println("Knopf");
  for (int i = 0; i < 60; i++)
    strip.setPixelColor(i, strip.Color(0,0,0));  // Ausgeschaltet
strip.show();
BLYNK_WRITE(V3) {
    strip.setPixelColor(i, strip.Color(255,0,0));  // Rot
strip.show();
BLYNK_WRITE(V4) {
    strip.setPixelColor(i, strip.Color(51,51,255)); // Blau
strip.show();
BLYNK_WRITE(V5) {
    strip.setPixelColor(i, strip.Color(51,153,0));  // Grün
strip.show();
BLYNK_WRITE(V6) {
    strip.setPixelColor(i, strip.Color(255,255,0));  //Gelb
strip.show();
BLYNK_WRITE(V7)
  strip.setBrightness(param.asInt());
//Theatre-style crawling lights with rainbow effect
BLYNK_WRITE(V8) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
  strip.begin();
  strip.show();
  Serial.begin(57600);
I can’t get the last button (vPin 8) to run till I select another button. Kind of like an infinite loop, but one that I can break when I want to have just another colour. Can someone help me, please?
This is not a code factory. Your last topic was shut down as it was not Blynk specific and we are not code monkeys. We teach you about Blynk, not how to program.
Look into timers, and other ways to run continuous loops without causing Blynk disconnections.
http://docs.blynk.cc/#blynk-firmware-blynktimer
Search this forum for other FastLED projects, read them, study them, test them, learn :stuck_out_tongue_winking_eye:
Blynk - RE-SEAR-CH
