I am running android and using the Wroom32 module (NOT the full dev board).
The module itself it working perfectly fine in terms of uploading and using it as a basic uC. Additionally, when configuring with the bluetooth widget in the app, the device is showing up.
When I try to run the app, the module isn’t able to connect (this device was never online). I tried running the same code with an ESP32 dev board and it works perfectly fine. I updated the auth code and changed the target device in the bluetooth widget.
