Hello from Hamburg,
i use a Arduino Nano 33 IOT and a Raspi 4 as Local Server.
the first connection works fine. but if the arduino lose the connection, it uses a wrong IP address for reconnect. for example: the Server-IP is 10.3.141.1. but if the Arduino reconnect, then it uses a totally diffrent IP.
is this a Problem of my Sketch, or a problem of some other files ?
