Hy blynkers,
I need your help. I have got an ESP32 with two switches and two LED´s. When I turn on switch1 the led1 and a led red in blynk schould turn on. When I turn on switch2 the led2 and led green in blynk schould turn on. The hardware already works correctly. But my code isn´t able to turn on any led an blynk. Here is my code:
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
int Status_Tommy;
int pushButton1State;
int Status_Gabi;
int pushButton2State;
char auth[] = "XXX"; // Put your Auth Token here. (see Step 3 above)
char ssid[] = "XXX"; //WlAN Name
char pass[] = "XXX"; //WLAN Passwort
#define LED1 12 //red (Tommy)
#define LED2 13 //green (Gabi)
#define Button1 5 //Tommy
#define Button2 19 //Gabi
#define VPIN_BUTTON_1 V10
#define VPIN_BUTTON_2 V11
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
// When App button is pushed - switch the state
pinMode(LED1, OUTPUT);
pinMode(Button1, INPUT_PULLDOWN);
digitalWrite(LED1, Status_Tommy);
pinMode(LED2, OUTPUT);
pinMode(Button2, INPUT_PULLDOWN);
digitalWrite(LED2, Status_Gabi);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
void checkPhysicalButton()
if (digitalRead(Button1) == HIGH) {
digitalWrite(LED1, HIGH);
Blynk.virtualWrite(V10, HIGH);
Blynk.virtualWrite(V10, LOW);
digitalWrite(LED1, LOW);
if (digitalRead(Button2) == HIGH) {
digitalWrite(LED2, HIGH);
// Update Button Widget
Blynk.virtualWrite(V11, HIGH);
Blynk.virtualWrite(V11, LOW);
digitalWrite(LED2, LOW);
Can you please help me?
