Wire library
Hi friends,
I manage to connect my ardujno pro mini to Esp-12 via wire protocol and all communication works fine.
this sistem works like this
Nano sends values to ESP
ESP recieve values via Wire and update on the app
ESP gets values from Virtual Pin and send value to Nano
Nano gets values and does some stuff
my code is like this
Blynk.virtualWrite(V0, Th);
Blynk.virtualWrite(V1, HR);
Blynk.virtualWrite(V2, Watt);
Blynk.virtualWrite(V3, Volt);
Blynk.virtualWrite(V4, Amp);
Trasmission();
Request();
BLYNK_WRITE(V5)
int widgetValue = param.asInt(); // Here we create variable to store incoming values from V1.
if (widgetValue == 1) { //if Button Widget value is 1 (HIGH)…
TWatt = (TWatt - 10);
Blynk.virtualWrite(V7, TWatt);
BLYNK_WRITE(V6)
TWatt = (TWatt + 10);
BLYNK_WRITE(V8)
HRZone = (HRZone - 1);
Blynk.virtualWrite(V10, HRZone);
BLYNK_WRITE(V9)
HRZone = (HRZone + 1);
I think i understood that the library wire.h gives problems to blink
i have it connected to pin 12 and 13, is there any possibilty to disable from blynk?
