First off, I would like to thank this community for the help and the abundance of information.
I have no understanding of codding. as was able to put this project together by reading and a lot of trials and errors
I obtained this defective wine chiller from local add for free , with the idea of converting it to a cigar humidor.
Since it was a dual zone chiller, i decided to leave the top section as wine storage compartment which is neither chilled or cooled , after all i gutted the whole cooling parts ( compressor and wiring) out of the unit.
to cool the cigars i added a Peltier cooling fan and for humidity I’m using a small ultrasonic mist atomizer humidifier.
i copied the code from this community member KSinning ,and modified it to be able to run both relays to control temp./humi
here is the code
#include <DHT.h>
#include <WidgetLED.h>
char auth[] = "xxxxxxxxxxxxx";
#define DHTPIN 12
#define DHTTYPE DHT22
const int relay1 = 5;
const int relay2 = 4;
int humLowTrigger;
int tempHighTrigger;
DHT dht(DHTPIN, DHTTYPE);
void updateHum(int param);
void updateTemp(int param);
BLYNK_WRITE(V7) {
updateHum(param.asInt());
BLYNK_WRITE(V8) {
updateTemp(param.asInt());
void Readdata()
float h = dht.readHumidity();
Blynk.virtualWrite(V10, h);
Blynk.virtualWrite(V11, h);
Blynk.virtualWrite(V20, t);
Blynk.virtualWrite(V21, t);
Blynk.virtualWrite(V15, relay1);
Blynk.virtualWrite(V25, humLowTrigger);
Blynk.virtualWrite(V24, tempHighTrigger);
if(h < humLowTrigger) {
digitalWrite(relay1, LOW);
Blynk.virtualWrite(V26, 0);
digitalWrite(relay1, HIGH);
Blynk.virtualWrite(V26, 255);
if(t < tempHighTrigger) {
digitalWrite(relay2, HIGH);
Blynk.virtualWrite(V27, 255);
digitalWrite(relay2, LOW);
Blynk.virtualWrite(V27, 0);
void updateHum(int param) {
humLowTrigger = param;
void updateTemp(int param){
tempHighTrigger = param;
Blynk.begin(auth, "xxxssx", "xxxxxxx");
timer.setInterval(1000, Readdata);
dht.begin();
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
int humLowTrigger = 65;
int TempHighTrigger = 20;
Now my problem is every thing runs fine until there is power outage or my iPhone dies
the the system shuts down until i touch the sliders on blynk app
Help please how can i fix this
I’m using feather huzzah board
thank you
