BLYNK_WRITE(V12)
if (param.asInt() == 0)
Serial.println("111111111");
if (param.asInt() == 1)
Serial.println("2222222222");
Cannot print message such as "1111111111111"or“22222222222”
BLYNK_WRITE(V12)
@shuaiqi “something” has to == 0
The param.asInt() function has to have an Integer to work with.
Try this:-
BLYNK_WRITE(V12)
int someThing = param.asInt();
if (someThing == 0)
Serial.println("11111111");
else if (someThing == 1)
Serial.println("22222222");
Richard
char auth[] = "f3ccdd5671264c4*****************";
char ssid[] = "HiWiFi_0EC3A4";
char pass[] = "test1234";
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, IPAddress(47,24******), 8080);
BLYNK_WRITE(V111)
if (someThing == 0)
Serial.println("5555555555555");
Serial.println("666666666666");
Serial.println("dddddd");
I can’t print out 555555555 or 6666666
Please help me, thank you very much.
I think you need to go right back to the beginning.
Learn how format your code properly for this forum as detailed when you started this post i.e. use 3 back ticks + ccp at the beginning and 3 back ticks at the end. Your code should look like my example.
Learn about program construction i.e. what to put in Setup (this will only be run once at startup) Your BLYNK_WRITE(V111) will only run once!
Learn about what you can and cannot put in the loop() function. Serial.println(“dddddd”) will try to print 100’s of times a second.
Have a look at some Blynk examples regarding wifi and Blynk connection.
Richard
The problem is that nothing can be printed
I am confused
This can’t print 0 or 1, I don’t know where the error occurred, please help me. Normally it can be printed, maybe my system is wrong?
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
char auth[] = "f3ccdd5671264c46***************3";
Blynk.begin(auth, ssid, pass, IPAddress(4*********,65), 8080);
BLYNK_WRITE(V123)
int prinValue = param.asInt();
Serial.println(prinValue);
@shuaiqi you’ve been asked twice to format your code so that it displays correctly - once in the template text that you deleted when creating your first post, and then again by @rha10
Please go back to your posts that contain code and edit them, by clicking on the pencil icon at the bottom of each post, and add-in the trippier backticks ``` at the top and bottom of your code.
If you don’t do this then your code will be deleted.
Thank you.
I took pity and did it for the OP
You’re getting soft in your old age!
I found the reason, it was a server problem (my own server), my server version is 41.1. I did not see this phenomenon with the blynk server, so I want to update my server. How do I update the server? What do I need to do before updating? Thank you very much for your patience!~
I found the reason, it was a server problem (my own server), my server version is 41.1. I did not see this phenomenon with the blynk server, so I want to update my server. How do I update the server? What do I need to do before updating? Thank you very much for your patience!~。。。
