Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
Means compare it to what is listed… if it is close to one of the other WiFi adapters, then it might work the same way… then trial and error. If constant error, than probably not compatible.
I found another ost where someone is using the adafruit WINC1500 wifi board #define BLYNK_PRINT Serial // Blynk #include <SPI.h> // Blynk #include <WiFi101.h> // Blynk #include <BlynkSimpleWiFiShield101.h> // Blynk
