Wifi module broken ?!
It just suddenly stoped working… I connected it to my PC to look at the Serial output:
[29] Blynk v0.3.1
[530] Connecting to NETGEAR69
ATE0
[1546] Failed to disable Echo
AT+CIPCLOSE
AT+CIPSTART="TCP","cloud.blynk.cc",8442
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
AT+CIPCLOSE
I used it to run a relay (I know how to connect it (Diode etc.)) and some sensors. I think something was wrong with the power connection (the ESP8266 got really hot (I used a logic converter and 3.3V)
Hardware: Arduino Nano, ESP8266 WiFi module, HTU21D Humidity Sensor (Sparkfun)
And here is the code:
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use ESP8266 Shield via Hardware Serial
 * (on Mega, Leonardo, Micro...) to connect your project to Blynk.
 * Note: Ensure a stable serial connection to ESP8266!
 *       Firmware version 1.0.0 (AT v0.22) or later is needed.
 *       You can change ESP baud rate. Connect to AT console and call:
 *           AT+UART_DEF=115200,8,1,0,0
 * Change WiFi ssid, pass, and Blynk auth token to run :)
 * Feel free to apply it to any other example. It's simple!
//#define BLYNK_DEBUG
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
#include "SparkFunHTU21D.h"
HTU21D myHumidity;
// Set ESP8266 Serial object
#define EspSerial Serial
ESP8266 wifi(EspSerial);
char auth[] = "**************************";
  // Set console baud rate
  // Set ESP8266 baud rate
  EspSerial.begin(9600);
  myHumidity.begin();
  Blynk.begin(auth, wifi, "NETGEAR69", "*****************");
  //here
  //here
  //here2
  void humi()
  float humd = myHumidity.readHumidity();
  Blynk.virtualWrite(5, humd);
void tempe()
  float temp = myHumidity.readTemperature();
  Blynk.virtualWrite(6, temp);
//here2
BLYNK_READ(V5) // Widget in the app READs Virtal Pin V5 with the certain frequency
  // This command writes Arduino's uptime in seconds to Virtual Pin V5
 humi();
BLYNK_READ(V6) // Widget in the app READs Virtal Pin V5 with the certain frequency
  tempe();
*update
I get this here from the Serial Monitor:
but I can’t send any commands :confused:
The module is broken, but I had another one (that WAS broken) I needed to flash the Firmware, now it Works fine :smiley:
