BLYNK
BLYNK.IO       šŸ“² GETTING STARTED       šŸ“— DOCS       šŸ‘‰ SKETCH BUILDER
Wifi connection works, but no backend connection
I have the Sunfound 3in1 Kit and now try to get started with blynk. I have arduino with esp8266 with this cabeling https://docs.sunfounder.com/projects/3in1-kit/en/latest/_images/wiring_23.jpg
/* Fill in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "TMP*****"
#define BLYNK_TEMPLATE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "bWf8V1********"
#include <ESP8266_Lib.h>
char ssid[] = "******";
char pass[] = "*****";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
  Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
I get a connection to the Wifi, but it looks like it never try to reach the blynk backend. I get no connection timeout or anything else
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v1.2.0 on Arduino Uno
#StandWithUkraine https://bit.ly/swua
[647] Connecting to ***
[3843] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
compile time:May 20 2016 15:08:19
OK
[11121] +CIFSR:STAIP,ā€œ192.168.179.13ā€
+CIFSR:STAMAC,ā€œd8:bf:c0:c0:5d:3aā€
[11131] Connected to WiFi
Somebody has an idea to get backend connection?
Thanks & regards
I’d start by rebooting your router.
Hi Pete,
I restarted the Router, but this not works. When I tried over a mobile hotspot it works.
Could it bei with the frequency of the WiFi? Mobile hotspot had only 2,4Ghz, Fritzbox offers 2,4Ghz and 5Ghz under same SSID. Strange that connection with WiFi works with Fritzbox but Connection to Internet Not.
Kind regards,
Nils
ESP boards only operate on 2.4GHz.
Having the same SSID for 2.4 and 5GHz may be an issue.
