When I declare a WidgetTerminal object in my project, it causes sprintf to return zeros for floating point and doubles. I am running the project on an Arducam CC3200 Uno using the RedBearLab WiFi Mini configuration in Energia. The following code sample illustrates the issue"
char auth[] = "{ProjectAuthToken}";
char ssid[] = "{SSID}";
char pass[] = "{PASSWORD}";
WidgetTerminal terminal(V1);
test();
void test() {
char buffer[10];
sprintf(buffer, "%f", 123.45);
Serial.println(buffer);
The output from sprintf is “0.000000” if WidgetTerminal is declared. If I comment out “WidgetTerminal terminal(V1);” then the correct serial output is displayed as “123.45”.
Here is a screenshot to illustrate:
