Hi, I’m continuing my tests of the Blynk library and this time I decided to mix a few Widgets and testing interrupts as well. I got the inputs from the various test programs provided with the library:
A Value Display shows some sequential values generated using millis() and periodically published to the could server using the SimpleTimer. This should simulate the readings from a set of sensors.
I added a physical switch button tied to an interrupt line and my goal is to display the status of the button using a couple of LEDs in the Blynk app that are turned on alternatively (just for fun…).
This is what I observe:
A) It seems a large number of reconnect to the servers are needed, but this could be a temporary (hopefully) server issue…
B) As the program starts, the timer function periodically (1 s) publishes the simulated sensor values
When I push the physical button the ISR is entered and the the LEDS in the app are turned on/off,
C) After a few clicks of the switch button, the timer callback is called NO MORE and the values no more updated, either the periodically generated ones and the LED values-
D) The ISR is correctly called, given the Serial printouts.
So it seems that after a few clicks the library enters a “suspension status” and the app is no more updated.
Considering I am calling the blynk functions either from within an ISR (as in the button example) and in the main program, I think the blynk functions are not re-entrants of “interrupt safe”.
Is this the case ? Any suggestion?
In the following text you can see the source code (if you want to test) as well as the Serial printout.
Best regards
Luciano
// LEDs, Interrupt Switch and Display
#include <Ethernet.h>
#include <BlynkApiArduino.h>
#include <BlynkWidgets.h>
#include <WidgetBridge.h>
#include <WidgetLED.h>
#define SWITCH_PIN 2
char auth[] = "token";
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// assign an IP address for the controller:
IPAddress ip(192, 168, 1, 113);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress dns_ip (192, 168, 1, 1);
IPAddress subnet_mask(255, 255, 255, 0);
IPAddress blynk_server_ip (45, 55, 195, 102);
SimpleTimer timerSensors;
WidgetLED led1(1);
WidgetLED led2(2);
// Callback to update Blynk Virtual Pin is button is pressed
void checkSwitch() {
Serial.print("ISR\n");
if (digitalRead(SWITCH_PIN) == 1) {
led1.on();
led2.off();
Serial.print("SWITCH is ON\n");
led1.off();
led2.on();
Serial.print("SWITCH is OFF\n");
// sendSensorValues: simulates sensor values
void sendSensorValues() {
int value1=0;
int value2=0;
value1 = millis()/1000;
value2 = millis()/100;
Serial.print("Values: v1=");
Serial.print(value1, 1);
Serial.print(",\tv2=");
Serial.println(value2, 1);
// Publish simulated sensor values to Blynk
Blynk.virtualWrite(10, value1);
Blynk.virtualWrite(11, value2);
// SETUP
pinMode(SWITCH_PIN, INPUT);
attachInterrupt(0, checkSwitch, CHANGE);
Blynk.begin(auth, /*"cloud.blynk.cc"*/blynk_server_ip, 8442, ip, dns_ip, gateway, subnet_mask, mac);
while (!Blynk.connect()) {
// Wait until connected
Serial.println("Connected to Blynk, starting... ");
led1.on();
led2.on();
timerSensors.setInterval(1000, sendSensorValues);
// give the sensor and Ethernet shield time to set up:
// LOOP
timerSensors.run();
OUTPUT
[0] Using static IP
[0] Blynk v0.2.1
[1300] My IP: 192.168.1.113
[1301] Connecting to 45.55.195.102:8442
[8122] Connecting to 45.55.195.102:8442
[14944] Connecting to 45.55.195.102:8442
[52245] Connecting to 45.55.195.102:8442
[89545] Connecting to 45.55.195.102:8442
[126846] Connecting to 45.55.195.102:8442
[127075] Ready!
Values: v1=128, v2=1280
Values: v1=129, v2=1290
Values: v1=130, v2=1300
Values: v1=131, v2=1310
Values: v1=132, v2=1320
Values: v1=133, v2=1330
Values: v1=134, v2=1340
Values: v1=135, v2=1350
Values: v1=136, v2=1360
Values: v1=137, v2=1370
Values: v1=138, v2=1380
Values: v1=139, v2=1390
Values: v1=140, v2=1400
Values: v1=141, v2=1410
Values: v1=142, v2=1420
Values: v1=143, v2=1430
Values: v1=144, v2=1440
ISR
SWITCH is ON
ISR
SWITCH is OFF
Values: v1=145, v2=1450
Values: v1=146, v2=1460
Values: v1=147, v2=1470
Values: v1=148, v2=1480
ISR
SWITCH is ON
ISR
SWITCH is OFF
Values: v1=149, v2=1490
Values: v1=150, v2=1500
Values: v1=151, v2=1510
ISR
SWITCH is ON
ISR
SWITCH is OFF
Values: v1=152, v2=1520
Values: v1=153, v2=1530
Values: v1=154, v2=1540
ISR
SWITCH is ON
ISR
SWITCH is OFF
ISR
SWITCH is ON
ISR
SWITCH is OFF
