Widgets on several sides
Hello community,
I want to use more widgets in my blynk app as allowed on one side.
My idea :
Is it possible to change between several token in the arduino mega when pressing a button for example?
In the arduino I use a flag that buffers the actual Status and runs different parts in my program including synchronizing arduino with the blynk Server with different token.
It means that I can create several Projects in the app and use different programs in the arduino.
Thanks for ideas
Carlos
I guess it can be done, but I think it will require some interesting logic. You can connect/disconnect to Blynk projects with Blynk functions so if you add logic and multiple auth tokens it can be done. I’ve seen it here somewhere on the forum.
I think it is just better to wait for Tabs widget.
What means tab Widgets ?? Is there any suggestion of realiziation nearly?
@alphakasi
Have you tried Bridge Widget? There is an example sketch in the library with some information on how to use it
