I’ve tried both Blynk V1 and 2.0 and Zero’s are dropped in the App display? In Blink V1 it was a value display and in V2 it’s a String.
I’m using the example sketch as reference.
It this how it is or is there a work around?
The problem is the way in which you’re constructing the string in your sketch.
Take a look at the sprintf
function to format your string correctly with leading zeros.
Thank you @PeteKnight that did the trick!
Still got a lot to learn and sometimes the “KISS” philosophy isn’t enough.
Cheers
